Question about Craftsman 10" Table Saw
My craftsman 10 inch table saw vintage late 70's early 80's is making excessive noise and when cutting the blades slow to a stop
  • 867 Answers
Electric motor needs a rebuild, bearings and brushes worn
Posted on Jul 25, 2009
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
Table saw stopped when cutting a dense piece of wood. Now just hums when turn it on. Not locked up, the pully will move by hand. Do you think replacing the capacitor will work. No restart button. ...
One thing you might try is to raise blade to highest setting possible and spin blade as rapidly as you can by hand and turn on while blade is still moving. see If motor will go ahead and come up to speed or try to I would replace start capactor. Also check brushes and make sure motor is clean and free from saw dust. Lube motor if equipped with oil ports. I would just use 3-4 drops and wipe off excess. Blow out with compressed air and also make sure belt is not to tight. I hopes this helps you, Thanks
Nov 17, 2010 | Craftsman 10" Table Saw
Blade Depth
Aren't there two handcrank wheels on the sides of the saw? One is for blade angle of cut, the other is for depth of cut.
Jun 07, 2010 | Craftsman 10" Table Saw
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
May 11, 2010 | Craftsman 10" Table Saw
What kind of dado blade can I use on my craftsman 10 inch table saw model no. 137.248100/ with stand
You have a 5/8" diameter arbor. You can use any dado blade that will fit. That said here's a few things to bear in mind.
8" diameter dado stacks are pretty standard for 10" contractor table saws. A dado stack is typically about 13/16" wide at most. It makes sense that the wider your blade is, the more power it takes to cut through the wood.
If you were to use the full width capacity of your Dado stack (13/16") a 10" diameter stack would bog down. A 8" stack has a faster rotation at the cutting edge because of its smaller radius. So, you don't bog down when you're making a wider cut if you use a smaller diameter.
If your machine was really underpowered, you could go down to a 6" stack which would cut your power requirements even more, but limits the depth of cut.
If this post was helpful, please vote. Thanks.
Mar 28, 2010 | Craftsman 10" Table Saw
Replacement blade
Use a 10" blade. As for the number of teeth...the more teeth the finer the cut will be. The only drawback is a a finer toothed blade will cut slow. For your purposes I'd suggest a fine toothed blade.
Mar 07, 2010 | Craftsman 10" Table Saw
Straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Jan 20, 2009 | Craftsman 10" Table Saw
Craftsman 10" Table Saw Logo
774 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
