Question about Dell Latitude D610 Notebook
My family has a Latitude D610. Recently my younger sister pushed open a door between a power outlet that the charger was plugged into, and a desk where the laptop was (also plugged in to the charger). The power charger was pulled taut across the doorway, so when my sister pushed open the door (she kept pushing when it met resistance), before I could get her to stop the computer suddenly shut off. Now it will not turn on! I think I know the source of the problem: I checked the power charger and found that the plug was slightly bent (my sister kept pushing), and that the metal needle inside of the computer-side end of the power charger was half as long as before! I assume this means that the other half of the needle is stuck inside of the computer. This would be a big problem of course, as the laptop would have no way to regain power and a replacement charger would not fit in; but the computer will not turn on, which i cannot explain as I have no idea why! (My best guess is a short circuit.) Please help by offering any sort of solution on any part of the problem you can. Thanks in advance, -Jack M.
  • JackMcG Jul 26, 2009
    Thank you very much, i have resolved my problem!
    President:
  • Dell Master
  • 1,996 Answers
See link here to troubleshoot the no power on condition, and see link here and here for checking ac adapter for damage and replacement.
Try removing the battery, disconnecting the ac adapter, and pressing the power button down for a few moments to discharge the unit. Then reinsert the battery and perhaps it will power up...But better to replace that adapter & perhaps have a local technician take a look at it to remove the broken pin before you cause any further damage to the system....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 25, 2009
    Sergeant:
  • 175 Answers
I'm sure that you can solve this issue if you know a little bit about circuits, otherwise you need to contact laptop repairing engineer.
Unscrew all your laptop and pull out the motherboard carefully. Look at the lower side of the motherboard, very next to the charger input point, there will be a Zener Diode, which looks like this.
For safety reasons, this Zener Diode on the supply circuit burn out immediately on short circuit. Find and replace this Zener. This will cost you about half dollar, and if you contact any repairing engineer, I think this will cost you about 50~75 Dollars. You better know what to do :)
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread with the results of your work.
Very Best of Luck!
Regards;
Hassan
Will keeping the ac plug connected kill my battery on Dell latitude d610?
I will suggest you to use laptop after it is full charge by removing the charger . when ever you feel battery is down then you can plug in the charger and keep using it, and when ever you see battery is full then remove the charger.
I'll not suggest you keep plugged in the charger when you are done, this way it can effect your Battery. and yes your battery can die with in a year if you are not follwing the correct way to use it.
Aug 15, 2012 | Dell Latitude D610 Intel Pentium M 1.6GHz...
My Dell Latitude D160 won't respond at all. I have to constantly push the power on button to even get it to come on and when it does, the battery light is on red and I think it says low critical power...
I'm confused too... it sounds like the power adapter is not (electrically) connecting to the laptop or the adapter is not delivering proper voltage/amps to the laptop.
You shoud 1. make sure that the AC plug is properly in the AC socket, 2. that the AC cord is (mechanically) connected to the adapter, and 3. that the adapter is (mechanically) connected to the laptop.
I cannot tell you how many laptops I have seen where the (internal) power connector breaks as a result of (typically) mis-handling, dropping, etc. Try (gently) wiggling the adapter connector and look for the LED changing colors.
You could also test the voltage output of the adapter with a standard Volt meter...
Sep 13, 2011 | Dell Latitude D610 Notebook
When I try to turn on my Dell D610 Laptop it immediately shuts off.
Hi
Try to remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON, see what happens
Please tell us your results
Good Luck
May 14, 2011 | Dell Latitude D610 Laptop Computer -...
Can't get DVD door to open.
Look for a little hole in the door and push a straightened-out paper clip in it. Push firmly and the door will open. Regards, nicam4
Jan 01, 2011 | Dell Latitude D610 Laptop Computer -...
My Dell Latitude d610 laptop will not turn on even when plugged.
im here to help but u may dislike what i say but please dont rate me bad for trying to help but..it could also be your laptop burning out that or the cord is cross wireing somewhere inside
Apr 09, 2010 | Dell Latitude D610 Laptop Computer -...
My Dell latitude d610 charging circuit not working on board
What needs to be done is the jack that your adaptor plugs into has solder points underneath it. All the solder points need to be resoldered to make sure that there are no cracks in the solder that are preventing the jack from charging your battery.
After this is done if the laptop still isn't charging then if you know for sure your using the correct ac adaptor with your laptop then at that point the moterboard would have to be replaced.
Jul 31, 2009 | Dell Latitude D610 Notebook
Battery stopped working
Hey,
Test your charger, the battery light blinking and the computer not starting up indicates not enough power to start up or not pluged into ac power, check the power adapter or charger. I suspect the battery is fine.
Thanks,
Ekse
Feb 15, 2009 | Dell Latitude D600 Notebook
I have a Dell Latitude D630, and I have had it for less than a year, and my charger is broken. I have it plugged in and everything, and it is not working. I plug the adapter into the outlet, and the...
sorry, i have to say this-- make sure the outlet works-- or try out a different outlet. :-)
ok, then make sure the connection is tight between the 2 parts of your adapter, it may have come loose.
other than that, you have a dead adapter. laptop companies are very good about replacing them for free under warrantee. they dont want fires starting at someones home because of a 30 dollar part.
i just called my laptop company, hp, 1 week before my 1 year warrantee ran out, and they shipped me a new power adapter, free, overnight.
call dell, tell them, they'll ship you a new one with usually free shipping, and usually in a day or two tops to your door.
Jan 31, 2009 | Dell Latitude D600 Notebook
Charging problem
It's definitely the motherboard based on the symptoms. You can send it to their out of warranty depot. Or you can purchase the motherboard from their spare parts sales dept, then look for a local tech who can install it for you.
Jan 02, 2009 | Dell Latitude D610 Notebook
Power for battery on DELL laptop Latitude D610 as posted FixYa
In the BIOS, does it show the battery and it's current state? As weird as it sounds, I've fixed an issue like this on a D600 by updating the BIOS to the most current level. Weird, but true.
Dec 22, 2008 | Dell Latitude D610 Laptop Computer -...
Dell Latitude D610 Notebook Logo
217 people viewed this question
Alun Cox
