SOURCE: I have a richo copier
you can change. You have a door right in front of the equipment. If you open that door you see the toner bottles. You pull the old one and then put the new bottle
Testimonial: "Thank you so so so so so much. You have solved my copier drama. Thanks so very much"
SOURCE: I have emptied the waste
There is no need to do that. Make sure the sensor is not out of the place.
If you take the wast bottle you will see a little sensor. Make sure is placed correctly.
By the way, what waste bottle is mentioned in the screen????
You have another waste bottle on the left of the machine.
Take the screws and you will see a white plastic bottle. Just empty it and your problem is solved.
Be careful, it is a little messy
Testimonial: "Thank you so much - another lesson learned - always happens on a Sunday! Several days better than Ricoh service! "
