Question about Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher
Kenmore 17369 When cycle starts... it sounds terrible (crackly sounding).... doesn't sound like the water is coming into the dishwasher. If I add water to the machine during a rinse cycle...it will wash and drain on its own.... Then I hit cancel. Please help.. I can't locate the owners manual.. Do you know where I can get one.. I understand that you can open the bottom up and see if there is anything lodged in the bottom of the dishwasher. Please help! thanks Cheryl
    Novelist:
  • 108 Answers
The problem is your water inlet valve.
If you remove the panel at the bottom of the dishwasher you will see either a copper hard pipe, or a flexible steel hose leading into the water inlet valve.
BE SURE TO CUT OFF THE WATER SUPPLY. It is probably located under the kitchen sink- just follow the water line until you see a cutoff handle.
Now (or first, if you prefer) cut off the power to the dishwasher, or if possible, unplug it. The valve is activated by an electromagnet (called a solenoid)- carefully remove the plug from the side of the solenoid (its best to use pliers so that you don't accidentally yank the wires out of the plug) on the valve.
Now, loosen the nut that connects the water line to the valve (a small adjustable wrench works best, but it's a tight space, so be patient.) disconnect the water supply hose and remove the valve.
Check and see if the screen (just inside where the water supply line connects to the valve) is clogged with limescale. If it is, you can clean it out fairly well with CLR or Limeaway, and that might fix your problem. If it doesn't you can order a new one online, or take it to an appliance parts store if there is one in your area. They are pretty common. If you do order it online, be sure to look it up using the model number of your unit (usually on a sticker on the inside of the door. Different models might use sightly diffferent valves depending on where under the machine they are attached.
Good Luck!
Posted on Jul 25, 2009
My dishwasher surges at the start and end of the cycle but still washes ok. Is this a problem, it doesn't sound right?
Some dishwashers depending on their programming rotate the motor impeller backwards at the start and end of the cycle to clear blockages, Also they can sound like they are surging if the water is a bit harder than it expects,
Keep and eye on the machine, as long as it doesn't demonstrate any other odd behavior it will be fine.
Mar 04, 2012 | Dishwashers
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Kenmore Dishwasher takes excesive amount of time to run, and dishes are not that clean and dosent seem to dry very well
    Hi
    If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
    If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
    Daniel
    Mar 22, 2011 | Kenmore 24 in. 17362 / 17364 / 17369...
    My knemoor dishwasher doesn't seem to be getting water. When I dump water in to the machine it runs but otherwise it seems to be water starved??help!
    It sounds like the pump, the function of which is to pump water into the machine. Since it works when you add water manually, it doesn;t sound like a switch or anything.
    A pump is easy to replace. It's usually attached with just a few screws/bolts and the hoses.
    Feb 14, 2011 | Kenmore Dishwashers
    I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
    I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
    Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
    When starting wash cycle the dishwasher cda cw447 doesnt appear to be getting enough water in and is making a droning / whirring / electrical ? noise. pipes all connected ok inc aquastop water supply unit,...
    Try removing the inlet pipe, and refitting, might fix it, else likely that the
    Inlet water soleniod failing/failed or tiny mesh filter (it does come out for cleaning) behind the inlet hose clogged. Temporaily bypass the aquastop water stop unit; it might be the culprit!
    A replacement solenoid is usually only about £10 from www.espares.co.uk, or ebay sellers (no connection with these but they are very good), fits in minutes (2 or 3 electrical spades ,and a posidrive or two) and usually fixes all water related problems. the noise you can hear is probably the solenoid trying to actuate, will be droning/buzzing sound.
    could simply be stuck with some foreign matter in there that's got through the mesh filter but unlikely. they normally fail and sound terrible.
    Don't throw your dishwasher away for the sake of a £10 part.
    Good luck
    Sep 12, 2009 | Dishwashers
    Kenmore dishwasher has loud noise during fill. If you let it go, the washer fills. Once filled, noise stops and wash cycle continues. Sounds like plumbing does when there is air in the pipes. Not a...
    This isn't a solution but rather a comment, if the problem is happening only during the fill, then it could be the water inlet valve. Perhaps there is a soliniod going in the valve, watch to see if the fill cycle starts to dimminish over time. Does the sound come anytime the washer fills, ie: rinse cycle? if so I would replace the valve, probably 50 dollars would get you a new one and you can do it yourself to save a little more cash. good luck.
    Apr 19, 2009 | Kenmore Dishwashers
    AEG Dishwasher
    Are you using these all in one tablets? if so I would still advise to add salt as without this you will get limescale build up espesially if you are in a hard water area, hopefully this will solve your problem.
    Nov 26, 2007 | Kenmore 24 in. 17362 / 17364 / 17369...
    Dishwasher Problem -REVISED
    Debris in the pump. Professional service required.
    Jun 05, 2007 | KitchenAid KUDC02IRB Dishwasher
    Kenmore 24 in. 17362 / 17364 / 17369 Built-in Dishwasher Logo
    124 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
