Question about GE Dishwashers
Dishes have a small amount of crud and water on them at end of cycle no matter what wash cycle I use.
    Novelist:
  • 108 Answers
You may have a problem of limescale buildup. First, I would suggest removing the lower rack, and trying to wipe out the bottom of the dishwasher as well as you can, and if you have a wet vac, vacuum off the filter screen. Then run a cycle with either CLR or a large bottle of lemon juice or a bottle of white vinegar.
Also, you may have a problem with rinse aid not dispensing, but make sure it is full if you didn't check already.
Posted on Jul 25, 2009
  • StanStihl Jul 25, 2009
    Also, if/when you do the limescale remover/lemon juice/vinegar trick, set the dishwasher so that it does one of it's longer cycles... I don't know exactly how your dishwasher is set up, but when you hear the soap dispenser open (which shouldn't have anything in it) that is when you should add your treatment. This will allow it to circulate longer in the dishwasher than if you add it at the beginning.
    You might want to run it a second time with just water after you are done.
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Soap remains on the dishes after the wash cycle is complete.
Check that the holes in the spray arms haven't blocked up and the filters in the bottom are clean. The arms may not be rotating. To check this, when the machine is washing, open the door, turn all the spray arms to face the same direction, shut the door and leave running for about 30 seconds. Open the door again and look at the position of the spray arms. They should have moved.
Nov 25, 2013 | Samsung DMT400RHS Builtin Dishwasher
Kenmore Dishwasher has died part way through a wash cycle.
The control module has failed, you can check for broken solder joint s or obvious damage but it's hard to diagnose the exact cause remotely.
Mar 12, 2012 | Dishwashers
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Mar 05, 2011 | Haier HDC1804TW Dishwasher
White powdery film is on dishes at end of cycle.
Too much detergent. the amount of detergent should vary with the amound of soil left on the dishes. Most users will pre wash their dishes in the sink, but still use the full recommended amount of detergent. There is no soil for the detergent to bind with, so it builds up in the pipework of your dishwasher. when the water evaporates during the drying cycle, the detergent residue is left behind on your dishes. Run a cycle or two with your dishwasher empty. add a cup of white vinegar to each cycle, but dont add any more detergent. After that, cut your detergent amount by half, and see if your issues go away. if not, please post the model and manufacturer of your dishwasher.
Nov 18, 2010 | Dishwashers
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
GE Potscrubber 650 does not drain and top rack not washed
your not draining the washed dirty water out. its leaving crud on dishes. check drain pump and drain line for restrictions
Jun 22, 2009 | Dishwashers
Standing water at end of cycle
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Apr 16, 2009 | Dishwashers
Dishwashers Logo
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
