SOURCE: how to scan documents then email them
To scan and send the documents via. e-mail. First of all you must run the setup from the cannon cd (comes with printer), use full installation (recommended option) complete the installation.
If this is already done then :-
1] Put the document that you want to scan in the scanner,
2]Open "control panel" and open "scanners and cameras" folder. (switch to classic view if needed)
3]Switch on the printer (if it's on only then proceed to next step)
4]You will see your scanner icon (if necessary refresh the screen)
5]Open it and click "next"
6] (OPTIONAL) Select scan image type.
7]Click "next".
8]Choose a place to save your image.(default is my pictures)
9]Click "next"
10]and now image scan starts, at last click on finished.
11]Now open your e-mail account, choose "compose mail" fill in the details
12]now select "browse" (for gmail) or select upload file
13]select the address of the image where you saved it (default my pictures)
14]click ok.(you can only upload 1 file at a time)
15]send the mail. !!
16]Thus, you can send image by scanning like as stated above .
SOURCE: walk through of how to set up 'scan to email' on RicohC3000
This is WAY more than a few lines to explain if you aren't familier with the setup. An IT person will likely be required if you can't figure it out via the "web image monitor" settings on your own...go to the IP address of the printer via a web page, Login (username: "admin" / Password: blank). make all the proper settings in tcp/ip, Email, etc., and it should work.
SOURCE: Tx2000 pavilion tablet cannot print anything!!!
there is an update on hp.com for tablet pc try updating the printer or uninstalling software
SOURCE: after installing the cd for lexmark x4650 printer
This could be a spooler problem. Refer to this article to enable the print spooler service on your computer: How to Restart or Reset the Print Spooler in Windows
