Question about Sony PlayStation® 3 (80GB) Console
My ps3 can't be rebuild database cause no hardisk found
Do any one hv the same problem or experience? is the hardisk damaged? need to replace hardisk?
do me a help ,thx!
  • boy4c6 Jul 26, 2009
    Would you please tell the details about how to use a laptop HDD to fix.Or should I buy a new HDD or just use the old laptop HDD plug in the PS3,then install the update software???
  • 52 Answers
Bad Drive or either your Files are corrupted. Would recommend getting a laptop hdd and seeing what happens.
Posted on Jul 26, 2009
  • Josh Peters
    Josh Peters Jul 26, 2009
    Read this Article on how to do it. Its very simple . I would buy the laptop hdd from ebay and if you dont have a external hdd as it says in there use a SATA/IDE xfer Cable to USB . Then you can pull the files off the old and put it on the new. Hope this helps
Ps3 says hard file disk corrupted and has to be restored but it just keeps doing this and has restored like 15 times and has not fixed itself. what can i do
1. Restore File System
Enter Safe Mode and select "Restore File System". "Restore File System" will attempt to repair damaged files on the hard drive. If this does not work, try the next step.
2. Rebuild Database
Enter Safe Mode and select "Rebuild Data Base". "Rebuild Data Base" will erase messages, playlists, changes made on [Information] screens, trimming information for pictures in [Photo], video thumbnails, video playback history and video resume information. Then attempt to rebuild the PlayStation 3 database. The content that is erased will not be recoverable. If this doesn't work, try the next step.
3. Restore PS3 System
Please note this will erase all content on the hard drive and will not be recoverable.
Enter Safe Mode and select "Restore PS3 System". "Restore PS3 System" will restore the default settings and will format the hard drive. If this doesn't work, try the next step.
4. Re-seat the hard drive
If you have replaced the hard drive in the PlayStation 3, make sure it was installed properly. If the hard drive is not seated correctly, it may cause problems.
5. Try another hard drive (if possible)
There may be an issue with the hard drive that is installed. Try replacing the hard drive with another one.
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
What happens if I rebuild my ps3 database
If you rebuild your Playstation 3 database, most of your memory would be cleared except:
Patches, Awards, Configured devices, Games, and some Internal Memory.
Contact me at mohammad7597@hotmail.com
Jan 05, 2011 | Sony Playstation 3 (PS3) Console
It plays movies for me, but not the games.
If still on warranty, use your warranty :)
If not try to do what i did.
I had exactly the same problem. I managed to fix it by executing so called Rebuild Database operation.
I followed these instructions;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu
Aug 17, 2010 | Sony Playstation 3 (PS3) Console
Friends disappear
try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
• Restart System: Restarts the PLAYSTATION®3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot read any disc.
But if your problem is not still solved, then maybe you should call sony for further assistance.
Good luck.
May 03, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will not play a ps3 disc
The PS3 has a special Recovery Menu, which you can access in the following way:
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
I have to rebuild my PS3 database, how long does it take?
my ps3 database for a game is at 0% how long will it be until its 100% i was going to turn off the sytem but would that make me loose my data
Nov 14, 2009 | Sony Playstation 3 (PS3) Console
Wont start messages comes up saying correct hard disk not found
your hard drive may be dying. or the file system may be corrupted.
before you get a new hard drive there are some tricks to try.
#1 remove the HDD and boot it up without it in, then turn off and put the HDD back in and boot again.
#2 rebuild the file system in the recovery menu
#3 rebuild the database in the recovery menu
To get to the recovery menu you need to press and hold the power button when the ps3 is in standby mode untill you hear a double beep then release. sometimes the ps3 will go back to standby mode before it does the double beep if it does just release the button and press and hold again real fast and wait for double beep.
here is what mine does
ps3 standby(red light) press hold power...........beep...............beep.........standby again, release hold............beep..................double beep ..release power button.
from the recovery consol you can rebuild the file system and database sometimes when they are corrupted it has same symptoms as a dying HDD.
P.S. rebuilding the file system and database will not lose any of your ps3 data, other options will though like the restore ps3 and format HDD.
if the above tricks dont work try updating the firmware, if your at the current firmware you can re-install it from the recovery menu as well using a usb memory stick or a cd with the firmware on it.
if all that doesnt help it looks like its time to get a new HDD, but at least you can upgrade it to a bigger ps3 now. any sata laptop HDD should work. i think a 160gb HDD is only $50ish.
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Yes my playstation 3 is saying hard disk needs to be rebuilt and it only says ok so i click ok another message pops up and says hard **** not found hard disk data will be deleted and lets you selesct ok or...
you could try to remove the hard drive then boot up, then put the hard drive back in and boot and see if that helps or you can try to rebuild the file system and database.
To get to ps3 recovery console to rebuild the database or the file system(neither will format the hard drive), when the ps3 is in standby mode(red light) press and hold the power button till you hear a double beep.
Most of the time the double beep comes after the ps3 beeps once then twice then turns red again when red again release and press again real fast and hold,... this time you will here a "beep" then " double beep beep" then you release and you will have the options to rebuild the database or the file system. basicly keep holding power button from standby till you here a double beep, if it shuts down try again, once you get the hang of it its easy.
if rebuild database and file system doesnt work then you may have to choose yes on the reformat option but it will wont hurt the ps3 itself just anything you have saved on it.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
Loading and saving doesn't work.
rebuild the file system and the database in the recovery consol.
to get to the recovery consol
when ps3 is in standby(red light) press and hold the power button till you hear a double beep then release. if the light turns red before the double beep quickly release and hold it again and wait again.
my ps3 goes like this
ps3 standby mode...press hold power button......."beep"......"beep"........standby again..release then hold real fast........."beep".........."double beep beep"....release and there are the options to rebuild database and filesystem. database and file system wont delete saveed files. i have some other tricks so let me know but try this first.
Sep 19, 2009 | Sony Playstation 3 (PS3) Console
It wont rebuild its database
you must of eraze the data base try to google it and put it on a usb!!! and plug it on your ps3!!! IT REALLY WORKS ACTUALLY IT WILL CLEAN IT!!!
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (80GB) Console Logo
433 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
