Question about Electrolux Gas Hedge Trimmer
Electrolux HG 18 gas hedge trimmer
I am looking for a downloadable owners manual. can anyone help?
Thanks
Firemont
  • 78 Answers
SOURCE: does anyone know the factory mixture setting
Carefully Bottom each screw and turn out 1 to 1 1/2 turns. This should get you started. Adjust low and high speed screws till it idles and does not hesitate on high
Posted on Oct 22, 2009
Testimonial: "Thanks for your help very useful"
kel1guy2002
  • 3740 Answers
SOURCE: Need an Owners manual for a Homelite gas hedge
https://register.homelite.com/contact_us/new
Go to this page and fill out the form then choose need manual in the drop down menu for type of inquiry
Posted on Jan 18, 2010
  • 29 Answers
SOURCE: Blades won't operate....motor is running - 18" gas hedge trimmer
centrifical clutch oily or slipping.
Posted on May 01, 2010
2strokeguy
  • 183 Answers
SOURCE: I am looking for a parts schematic for a sears
An illustrated parts list is readily available at www.searspartsdirect.com . Just input your model number and select model search.
The gas tank is located in the "crankcase" section.
As for gas tank repair, I have tried many times to repair these tanks. I have not been successful, even with the epoxies that are specifically made for it.
Good luck.
Posted on Oct 20, 2010
philwalker78
  • 608 Answers
SOURCE: What is the spark plug gap on a Electrolux/Partner
Hi, the gap should be .8mm or 30 thou. Hope this helps, regards Phil.
Posted on May 31, 2011
I have a hedge trimmer I have not yet used I cant find the manual can you please help the details are model hg550. pnc 953900593. ml 02.serial number 51106209. type 020. engine code ht2501b many thanks...
Goggle to find out the company that built it and see if they will send you a copy or if its available for download. This is a common problem with private sales without all the manuals that come with it. Sometimes you have to look up each appliance or model. Start with a phone number to the manufacturer and work from there. Also you can find someone that is selling one like yours and call them to see if they can send you a copy from their manuals.
Oct 10, 2013 | Electrolux Garden
Broken Tooth for GT90 Hedge Trimmer Gear
I need a manual for UT 31840 18 volt cordless hedge trimmer
Jul 04, 2013 | Dewalt Garden
Hi i wonder if you can help my Ryobi hedge trimmer has a problem with the pull cord it works goes in and out but it does not turn the engine over is there maybe a key way or something that maybe broken...
Hello Nick,
Inside the cord attaches to a plastic wheel which cranks the engine. This cord can become loose or can break after some use. Try opening the plastic casing where the cord is to see if this is the problem.
Thanks
Jul 25, 2011 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
What is the spark plug gap on a Electrolux/Partner HG 550 petrol (Gasoline) hedge trimmer
May 31, 2011 | Electrolux Garden
TrimmerPlus 720r Manual
Mine would start and run on the primer gas then die. Replaced the plugged fuel screen under the flapper valves on the single large screw cover of the carb. Runs well now
Aug 30, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Does anyone know the factory mixture setting screws for electrolux hedge trimmer
Oct 21, 2009 | Electrolux Gas Hedge Trimmer
Looking for owners Manual for Echo HC 1500 Hedge Trimmer.
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
Apr 02, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Electrolux Gas Hedge Trimmer Logo
336 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
