Question about Philips DVD712AT DVD Player
Philips DVD 712 player says it's reading a dvd but then opens
The dvd player tries to read a dvd but then opens. I took the cover off and the led does not light. Is this an easy thing to fix?
SOURCE: how to fix a insagnia dvd player
Simply put. Don't ever purchase an Insignia product ever. I Have the same problem with a product I purchased just over 3 months ago, and the Insignia Customer service rep Sandra Larraburu gave no help to me other than the following solutions.
1. Make sure all the cables are plugged in right (Are you serious Sandra?)
2. Try a different DVD (I told her in my original email that I had even been trying different DVD players, so of course that was done)
3. UnPlug it (Is this a solution?)
4. Plug it back in (O....kay)
Then she proceeded to tell me that because the manufacturer's warranty had expired after 90 days, that I was entitled to no resolve.
Note Insignia states this "All of us here at Insignia strive to provide the best quality products
and a
great customer care experience"
If that is the sign of a company striving, I've learned my lesson.
No Insignia for me again.
Posted on Feb 05, 2008
  • 47 Answers
SOURCE: DMR-EH55 DVD recorder is not able to read DVDs any more
You purchase a dry DVD lens cleaner and put it inside the tray. It will clean it for you. If you take apart the drive to expose the lens, you are actually at risk of making it worse.
Posted on Mar 09, 2008
SOURCE: WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Posted on Aug 28, 2008
  • 15 Answers
SOURCE: Philips Magnavox MWD200G DVD Player
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Posted on Mar 10, 2009
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
Dvd player tell me disk error
this could be aproblem with the lens which is unable to read the disk. this could be caused by accumulation of dirt on the disk sensor. open up the cover of the dvd player to access the lense and clean gently with a lense cleaner(a liquid purposely meant for cleaning the lense) apply this liquid on a soft piece of cloth and clean. close back the cover and power the dvd player it should now be able to load the disk
Sep 17, 2011 | Philips Magnavox DVD/VCR Dual Player
How can I stop a dvd player from reading non-stop with no disc in player---player is not on lock but refuses to open.
Power off, then disconnect from the wall plug.This resets the dvd. after five ninutes, reconnect the power and start the combo. Should have 'load' on the display, then open the tray of the dvd.When you close the tray, it will try to 'read' a dvd again.
Aug 16, 2010 | Philips Magnavox DVD/VCR Dual Player
Can't Read Disc
You could try updating the firmware.
Jul 06, 2010 | Philips DVP5990 DVD Player
I can't read Asian DVD. My wife arrive from Thailand and want to read her Original DVD. Have you got sollution?
Please check in the manual which region code (which is displayed at back cover of DVD) can be played on your DVD player. If the DVD brought from Thailand carries the same there should not be a problem but if it is different then it cannot be played. This must be the reason of not reading/playing. Solution lies that you should have a multisystem DVD player
May 03, 2010 | Philips DVD757VR DVD Player/VCR
Hi, my philips dvd player model number dvp3360/05 has stopped reading disks. Wjen it loads a disk instead of going to the start screen it just goes blank and on the LED display it says title. Any ideas on...
There are several reasons why your DVD player would stop reading discs.
1. Bad or dirty lens
2. Bad disc spinner motor
3. Busted capacitors on the mailboard
If you can open up your DVD player. Try to check for these problems.
Mar 14, 2010 | Televison & Video
Disc is not working. Error message No disc
Try cleaning both the disk and the lens of the dvd player. Sometimes even a little bit of dust can make your dvd player go ballistic. Brands like Sony,Philips and LG are very sensitive. If anything else fails, you can take it to a repair shop to find out if the lens isn't cracked or the LED isn't responding while trying to read the disk.
Apr 02, 2009 | Philips DVP3960
MY PHILIPS CDRW/DVD SCB5265 CAN READ CDs BUT CAN NOT READ DVD
I just installed Nero CD writing Software and Power DVD and it took care of the problem.
Jan 15, 2009 | Philips DVDRW 228 DVD+RW Burner
My dvd player will not read anything!
try opening up the dvd player unpluged of course, and cleane the laser with a q tip with alchol
Sep 25, 2008 | Philips Magnavox DVD/VCR Dual Player
Incorrect disc and bAd
I have the same problem, reads bad, won't play, took the top of a blow on it, alot, hoping dust would come off the lens, it did. Works now, also ran a disc cleaner in to after.
Have another dvd palyer, never had that problem, Philips.
Feb 25, 2007 | Toshiba SD-3980 DVD Player
Philips DVD712AT DVD Player Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
