Question about Apple iPod nano
Ipod is stuck on the language screen. Scroll
Ipod is stuck on the language screen. Scroll button, nothing works. Tried the Menu and centre button. Takes me to language screen and then that's it
  • 3 Answers
Push center and menu button same time
Posted on Sep 22, 2009
I have a apple ipod A1199 my little brother got a hold of it now its in some forien language that i cant read how do i get the menue to read american again?
No problem, you'll just need to do a full reset to restore the language to English.
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Feb 28, 2011 | Apple iPod Photo MP3 Player
Tip
Change iPod Language
Disconnect your iPod from your computer, then press the Menu button until the menu title says "iPod," regardless of the language displayed. This means you are at the main menu.
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
on Feb 10, 2008 | Apple iPod MA446LL/A MP3 Player
How do i change languages?. I'm stuck in Italian
  1. Open the "Impostazioni" app (Settings in Italian), denoted by the three gears icon.
  2. Tap on the "Generali" (General) tab (which shares it's icon with the settings app) to open it.
  3. Scroll down and open the "Internazionale" (International) menu.
  4. Tap on "Lingua" (Language) and select "English" from the menu.
  5. Tap the "Fine" (Done) button.
  6. Wait for the iPod to load the new language.
You will also want to disable the Italian keyboard, which can be accomplished as follows:
  1. Open the "Settings" app.
  2. Tap on the "General" tab to open it.
  3. Scroll down and open the "International" menu.
  4. Tap on "Keyboards" and tap the "Edit" button in the upper-right corner.
  5. Tap the red minus sign next to the "Italian" item, and then tap the red "Delete" button that appears.
Here's how to change languages while the iPod is set to English
  4. Tap on "Language" and select "English" from the menu.
  5. Tap the "Done" button.
Dec 27, 2010 | Apple iPod touch
I need to change the lanuage from japanese to engish on a ipod and I know absolutely 0 japanese
If you have an iPod nano or Fifth Generation iPod (iPod with video):
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
Apr 29, 2010 | Audio Players & Recorders
My ipod nano is stuck on language selection and does not let me scroll or do anything
hold the center button and the menu button till it shows the Apple symbol then let go and it should reset..if not plug it into a computer and use the reset on the iTunes
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
How do u change the language back to english
If this does not work.
Reset your iPod—Depending on how much you've used your iPod since selecting the language, simply resetting your iPod may cause it to forget the current language setting, enabling you to select a new one. See "How to Reset iPod" for instructions.
  • Connected. Eject before disconnecting
  • Sync in Progress. Please wait...
  • Do not disconnect
Note: When you reset your iPod, all your music and data files are saved, though you may need to reset some customized settings.
Jul 03, 2009 | Apple iPod nano MP3 Player
Language change
Hi, Let me provide you the steps to change the lnaguage on your ipod mini...
OR
Feb 21, 2009 | Apple iPod MA446LL/A MP3 Player
How to get my language back to english
Select your language.
for more details just click the link below http://support.apple.com/kb/HT1824
rate the solution if it helps. thanks.
Jan 05, 2009 | Apple iPod nano
Wrong language on ipod
This is simple but good to know.
-----John
If that doesn't work go to: http://support.apple.com/kb/HT1824
Nov 24, 2008 | Apple iPod nano
Ipod frozen on language screen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
Nov 24, 2007 | Apple iPod nano
Apple iPod nano Logo
884 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
