Question about Lenovo IdeaCentre K210 - 53133BU PC Desktop
Moniter's display related problem
A spotline has appeared in my monitor screen.It is situated from top to below in the middle of my monitor screen
  • 51 Answers
Try reinstalling your video card drivers. if this doesnt work try to degauss your moniter.
Posted on Jul 25, 2009
Luxor lux0140001B/01 1 week old picture has top half with a grey see through screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
Apr 12, 2014 | Televison & Video
Lg flatscreen monitor
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Dim screen
- Slow start
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Computers & Internet
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
Aadab: when the moniter ON after few second the moniter is does not give display and when we on and off the moniter so then the picture displayed why this problem is occure.how i recover it.
That is because the settings on the power are set for the monitor to go to sleep if not in use.. It is a very quick and easy fix.. Just right click anywhere on the desktop that doesn't have any icons, the display properties box will appear, then click on screen saver under monitor power click on power, there you could set the monitor never to turn off... Let me know if this solved the problem and good luck..
Sep 09, 2011 | Compaq Presario 5000 PC Desktop
Its LCD problem. Its unrepairable. This happen when unbearable weight has placed on laptop LCD or mishandling of the laptop. Better to ignore it or replace your LCD.
Regards;
Hassan
Jul 25, 2009 | Lenovo ThinkPad T500
I have a u220w monitor which has a rectangular screen but the picture is square leaving both sides black for about 3 inches on each side. I want to fill the entire screen. I just had the windows vista...
Dear You need to adjust the computer resoultion to one of the following..
1088 x 612
1280 x 720
1360 x 768
you can increase it more; depends on your graphic card installed in system..
HOw to change the resoultion??
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor.
Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Let me know if it helps...
rate me..
regards,
Dec 04, 2008 | Computers & Internet
Problem with data cord
Change the data cord if not repaired then change the monitor ,give another companies monitor
Aug 26, 2008 | Philips 105S51 15" CRT Monitor
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Screen on moniter is not full
I think that you need to reinstall or find a new driver for it.
Sep 02, 2006 | E-Machines eMachines Monitor E15T4
Lenovo IdeaCentre K210 - 53133BU PC Desktop Logo
94 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
