I can't get the back off to see what the problem is. I've taken all the screws out, the bottom is loose, the very top is loose, but something is holding it very firmly in the middle.
  • Mike Smith
    Mike Smith May 11, 2010
    What brand and model number ?
  • 867 Answers
There may be 2 screws where the lint filter is on top. pull out lint filter and check
Posted on Jul 25, 2009
I have taken 32 screws off the back of my VF552XVT vizio tv and still can not get the back off. The top is loose but the bottom is still tight. I don't see any more screws.
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Disassemble procedure to many popular devices are given with illustrations
May 01, 2017 | Vizio Televison & Video
How do I remove the cover of a delonghi ec270
Prise the back cover off with a flat head screw driver. Sides first, then ease top and bottom off. Remove two push in caps by gently squeezing out with a plier, align the groove to the same direction as plier. Locate two screws holding cover, unscrew, and off it comes.
Aug 25, 2012 | DeLonghi EC270 Espresso Espresso Machine
M101 keyboard replace
Keyboards are usually screwed in on the top of the laptop as well. Try to pop off the plastic cover above the keyboard, there should be little slots to allow you to take it off. Then there should be some screws under there for the keyboard.
Aug 02, 2012 | Advent Modena M101
Arrrrgh! I cannot lift the interior door panel off at the top after removing the 2 screws under the arm rest and the one in the rear. I've disconnected the power window, seats and door lock...
sometimes you have to have the bottom pulled out about a foot, and have the window down half way, and then wigge from side to side while lifting over the lip along the top of the door at the window line.
Jul 19, 2011 | Buick LeSabre Cars & Trucks
Hi i'm trying to take apart a toshiba satellite l655-s5096 and as far as I can tell I've got all the screws but it won't release. I've ben looking for a manual but I've had no luck. If...
take all the screws off the bottom (including the screws hidden by the optical drive), turn the laptop over, open it. there is a small strip of plastic right above the keyboard, pry it loose and remove the 4 screws from underneath to release the keyboard. disconnect all the exposed ribbon cables and any other cable connector that you can see. once you've done this pick a spot on one of the edges to start prying it apart. Use a small screw driver or plastic pry tool if you need it. (on this model I started with the top right hand corner.)
Jul 02, 2011 | Computers & Internet
Belling 351 MK2AN Oven Door bracket back plate fallen inside!!
The only to do it, is to remove the side panel , and depending on the model number, you may have to remove the top also to gain access to the fixing screws.
Please rate my solution.
Thanks.
Nov 07, 2009 | Belling Ovens
I need to open my Acer laptop case to solder to power switch
this may not be your exact model, but should give you a good general idea on how to get inside. The key is prying up the top strip, that seems like it is going to break. Use something plastic or wood if possible. A screwdriver will leave marks.
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Apr 02, 2009 | Acer TravelMate 512T Notebook
How to disassemble Mag innovision 19" monitor
Once the 4 screw at the bottom of the screen has been removed the frame surrounding the lcd should slide up and away. The display itself is fastened to the plastic back by 6/8 screws be careful when removing the lcd screen since it is still attached to the electronics in the back by cable connectors!
Feb 27, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Microvent is coming loose on the bottom of mounting.
Generally, these units are held to a backing plate with a pair of screws that are accessed by removing the vent plate above the door. There are a couple of Philips screws. Inside...at each end, there is a slot head screw head on a rod. Support the unit and back these screws out. The unit will then pivot from the bottom away from the wall. Detach it and then repair the issues with the hold bracket. Warning: these units are heavy!
Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
