Question about KitchenAid Refrigerators
Our ice maker does not work. The inlet where the water goes into the place to make ice, is not frozen & i put water in there to see if it would work. The water froze, but did not drop into the storage container. The water comes out of the door with no problem. Any help solving this issue would be greatly appreciated. Thanks in advance.
  • 4 Answers
You should check whether or not the icemaker (I am assuming it is an in-freezer model and not a stand-alone comercial icemaker) is is getting power from the plug in the freezer, and from there checking the switch on the arm that senses whether or not the storage container is full of ice
Posted on Jul 26, 2009
Ice maker not working and top of freezer not always frozen
when you put it back in for the last time does it do anything? Does it make any noise or movement. If it does then check to see if water is coming into the ice maker. if it is not then you may have a water inlet problem
Jun 03, 2014 | Maytag MSD2454G Side by Side Refrigerator
The water line that connects to the back top of the fridge busted loose. It looks like there is an adhesive pad that keeps it in place. How do I fix it? Scott
Hi Scott and welcome to FixYa, I am Kelly
The plastic line that connects to the ice maker rubber FILL tube is what came off. Check inside the freezer and squeeze the end of the rubber tube at the back of the ice maker. I would bet it is frozen with ice. (Hand held hiar dryer for quite a while to defrost the tube FYI and do NOT melt the plactic of the ice maker water funnel.) What causes the tube to freeze is the inlet water valve starts bypassing water when it is supposed to shut off. The result of this bypassed water is a frozen rubber tube and the plactic tube on the back of the refirgerator blows off or leaks. This inlet water valve is NOT repairable.
The Fix... Replace the inlet water valve and make sure the rubber ice maker fill tube is defrosted BEFORE re-inserting the plastic tube back into the rubber fill tube. It just pushes in and the adhesive pads for holding the plastic line in place are not critical even if they are lost. The rubber fill tube fitting will retain the plastic hose just fine as long as the ice maker end of the tube is not frozen from a leaking inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 14, 2011 | Refrigerators
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
My frigidarie refrigerator ice maker does't work
Jun 06, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
Icemaker not making ice
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
No water going to ice maker
Jun 06, 2010 | Whirlpool GC5SHEXNS Side by Side...
My superba is leaking water from the white block where the water feed line goes into the ice maker how can this be fixed ??
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak
The valve can leak because of sediment in the water preventing it from closing or low water pressure
. Disconnect the ice maker line from the water inlet valve valve(on the back where the water supply connects). and watch to see if it has a slow drip.
Nov 19, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
I just replaced my icemaker on a kenmore fridge #2537481240g I heard the soleniod(water valve) enage and the ice maker has gone thru 3-4 cycles but still no water? any suggestions?
Fill tube above ice maker may be frozen. Remove the fill line from the back of the unit where it comes out of the solenoid valve, force ice maker into a harvest put hose in a bucket and see if you get any water when it actuates the valve, the valve may have a clogged screen or not opening at all. If you get water, then you have a frozen fill tube
Jun 13, 2009 | Refrigerators
Refrigerators Logo
57 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
