Question about Pioneer Audio Players & Recorders
Pioneer PL-670 turntable won't play
Whenever the arm goes to the record, it will set down on it. But it quickly lifts off and moves back to the rest, not playing a sound from the record.
SOURCE: table turns only once in a while.
The problem is probably the belt. When a belt gets old it tends to stretch and/or get stiff. Listen to see if you hear the motor turning. If it comes on when you lift the arm, it is not the switch.
Posted on Apr 15, 2008
SOURCE: Pioneer PL-570 turntable (c.1973)
pioneer PL 570  tone arm drops and turntable shuts off,  what gives?
Posted on Jan 16, 2009
petraman7
  • 1175 Answers
SOURCE: PL-88FS with modern HDMI Receiver
Hi...
If the new receiver doesnt have a specific input in back labeled "phono" , You WILL need a preamp for the phono. Then plug the preamp into the AUX or other available input
Posted on Jan 19, 2009
  • 42 Answers
SOURCE: pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
Posted on Jan 24, 2009
  • 42 Answers
SOURCE: I have a AT-PL50 turntable.
Your submission was incomplete. Please resubmit.
Posted on Jan 25, 2009
I've recently picked up a Pioneer Plx-88z turntable second hand. I know that the player is working ok as putting the arm on the record plays music. The problem is that after a few seconds, no matter what,...
Hi, if it's a second hand device. there must be something wrong with the arm at it's moving axe. if something (dust or broken support) is blocking it, it will return automatically to its rest position to avoid any damage to the fragile and sensible "head"
Jun 02, 2014 | Audio Players & Recorders
Sony PS-LX250H Player arm won't set down to play
Have you made sure the "up/down" button is not depressed? It's the furthest button to the right of the player if you are looking at it head-on. If it is depressed, it will cause the needle to simply hover above the spinning record. A good thing if you want to "pause" your musical experience, but not much help if you are trying to enjoy some sonic sensations.
Nov 23, 2012 | Sony PS-LX250H Turntable
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
The arm won't stay down, as soon as it sets down on the record it automatically stop and moves back to the resting spot.
If you have the automatic arm on you`res and you have to move the slidder control to make it work,don`t slide the control all the way.Just til you hear a click and then move the arm you`r self.Also make sure it is set to the size record you are trying to play.
Apr 22, 2010 | Pioneer PL-990 Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Tonearm on turntable wont stay on record
Remove the motor assy and you will see the main nylon large gear, it had 2 metal cams under the one screw on top of it. One is the start cam and it must slide freely on top of the other one cam. Over time the grease binds up under the start cam and it doesnt move back in as the motor moves the nylon cogs around and so it start over gain and again. Degrease and lightly lube the metal cam so it moves freely by using your finger, reassemble and test.
Jan 31, 2009 | GPX S7799 Shelf System
Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Jan 04, 2009 | Audio Players & Recorders
Won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Jun 04, 2008 | Sony PS-LX250 Turntable
246 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
