Question about Kenwood KDC-M7024 CD Player
Power problem with my KDC-M7024
Recently when i turn my M7024 CD player on, the front panel flips down, but then all the lights go off and it closes back up as if it were to switch off but then opens up and closes. it just repeats this over and over. My initial thought is that the ribbon cable that runs to the flip panel has broken. What do you think? If so, is it easy to change and where can I find these cables to buy? Many thanks
Adrian Thomas
South Wales
  • Aj_1985 Nov 21, 2007
    I have just stripped my CD player down and have come to the conclusion that it is the ribbon cable. Does anyone know where i can purchase one?
  • 624 Answers
The part number for that cable is
This other cable going from the other display to the main board should also be replaced at the same time.
You can verify the part number by looking right on the cable, it is on the very end of the cable on the part that overlaps the connector the cable plugs into.
Only places i know that sell them are authorized kenwood servie centers. There should be one in your area.
please give me a "fixya" if this helps.
Posted on Jun 18, 2008
  • Dave DeGain
    Dave DeGain Jun 18, 2008
    Almost forgot, ther is also another common problem with this type of radio.
    The micro switch that is next to the gears that move the display in and out wil sometimes be out of postion or more accuratly, the lever that depresses the switch will get worn a little and not press the switch in completely. This can be fixed by carefully unsoldering the switch and moving it closer to the lever by about 1/16 of an inch and resoldering it into place. or you can order the lever and replace it, but you need to be able to re-align the gear that moves the lever properly or it will open too soon or too late.
    If this is the problem, it will turn on and open, then close back up and turn off very quickly.
    I can give you more information if you need it. Just coment on the post.
  • vittoriobona Jul 13, 2011
    can I get more info about this problem and maybe some photos of the microswitch. Stereo was working until a couple of days ago, only problem was that the screen tilt could not be adjusted. When I pressed the tilt button the screen would tilt fully outwards and then back in again.
    Now when I turn the stereo on, it opens partially and then closes and turns off.
    Any help would be greatly appreciated!
I just bought a car that has a kdc 516s and
You need to flip the front panel down first and there will be an eject button on the inside of the panel. If this is not working try pressing the tiny reset button which is left of the ATT button.
Nov 18, 2009 | Kenwood KDC-516S CD Player
My panel that flips down on my m7024, all a sudden started not functioning one button at a time, and now doesn't even turn on, i found though when i pushed cd eject when that button was working, all the...
You have a bad ribbon cable, very common on these units (That's why they don't make them anymore) If you don't have a local repair shop you can call Auto-Sound in Louisville, Ky 502-448-5606. will be about a $90 fix.
Aug 15, 2009 | Kenwood KDC-M7024 CD Player
Display disappeared on kdc 8021
If you mean that the rotating cover has flipped back round covering up the control panel turn on the ignition and push the top left of the panel. this should make the cover flip back around and make the interface available.
Jan 12, 2009 | Kenwood KDC-8021 CD Player
Ive lost the code to unlock my stereo can u help?
3. Simple way to clear the security code (K type only)
1) During code request mode, press the Track UP key for at
least 3 seconds while holding down the AUTO key. (– – – –
will disappear)
2) Enter, “KCAR” with the remote controller as described below.
• Press the remote controller 5 key twice, and press the
Track Up key. (Enters a “K” )
• Press the remote controller 2 key three times, and press
the Track Up key. (Enters a “C” )
• Press the remote controller 2 key once, and press the
Track Up key. (Enters an “A” )
• Press the remote controller 7 key twice, and press the
Track Up key. (Enters an “R” )
3) Security function is canceled and unit sets to All-Off mode.
4) Code request mode appears if a mistake was made in entering
the numbers.
This is the only way to clear the code, please give me a "fixya" if it helps
Jun 15, 2008 | Kenwood KDC-M7024 CD Player
Not working
send it to Merle radio co., 840 south ave. ,Plainfield, NJ., 07062
phone# 908-756-3544
Apr 06, 2008 | Kenwood KDC-7090R
Flip bit not working KDC-7090R
hi its going to be the flexi that connects the panel to the main pcb. you can buy a repair kit @
Blue ICE
Feb 26, 2008 | Kenwood KDC-7090R
Power problems with my kdc-x789
It should be taken back to the installer.
Oct 06, 2007 | Kenwood Excelon KDC-X789 CD Player
TOC Error
I had the same problem with my KDC-M7024 CD player. All I done was put a cleaning disc into the player and let it play for 2-3minutes. The disc has a small cleaning brush on it which spins around like a normal CD would and as the bristles pass over the laser it removes any dust.After that it worked fine but i still have to run the disc through every 3-4 months or the problem persists.
Dec 07, 2006 | Kenwood KDC-M7024 CD Player
Kenwood KDC-M7024 CD Player Logo
278 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
