Question about Sharp BQC-XGNV4SU/1 Projector Lamp for PG-D120U, XG-NV4SU
Light on my sharp xg-nv4su projector comes on for a few seconds then goes off. how do i reset the lamp timer?
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Posted on Oct 12, 2009
  • 5,603 Answers
The lamp life timer may have expired. If the lamp blows as they can at the end of life, damage can be done as they run at high pressure. That is why they have a timer.
Posted on Jul 25, 2009
SOURCE:
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
Need to reset lamp displayon sharp xg-e3500u
To reset the timer go to the link below. It has the instructions.
http://unitedvisual.com/Pdf/SharpxgeCounter_Reset.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 18, 2010 | Sharp XG-E3500 Multimedia Projector
My sharp pg-d120u turns on but no image. might be the bulb.
If you are nat getting an image then you need to replace the bulb.
Mar 21, 2010 | Sharp BQC-XGNV4SU/1 Projector Lamp for...
Sharp xg-nv3xe lamptimer reset
hod down enter, menu, and down arrow, then press power.
Apr 27, 2009 | Office Equipment & Supplies
SHARP XG-P25X PROJECTOR PROJECTOR RUNNING THEN IT IS AUTOLOG OFF AFTER 2MIN. WHEN PROJECTOR IS RUNNING ITS SHOW GREEN LED AFTER LOG OFF IT IS SHOW RED LED ON LAMP AND POWER LED
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
XG-C50
pls check the fans under the Optical Engine, under the prism
the fans easy to be failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Sep 04, 2008 | Sharp (BQCXGC50X1) Projector Lamp for...
Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Dec 07, 2007 | Sharp Notevision XG-P10XU Multimedia...
Having problems with my sharp notevision XG-C40XE
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
Aug 23, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Sharp BQC-XGNV4SU/1 Projector Lamp for PG-D120U, XG-NV4SU Logo
372 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
