Question about Magic Chef Dishwashers
Where do I put Jet Dry?
Where do I put liquid "Jet Dry"?
  • 5,603 Answers
IF your dishwasher has the capability for using JetDry, you will ind that on the door there is a plug thing that you remove and fill and replace it. The plug usually unscrews a quarter turn and then pulls out.
Posted on Jul 25, 2009
How to Clear out dish soap from the jet dry resevoir?
Use a shop vac and suck it all out. Then, spray some Pam-type cooking spray grease into the jet dry reservoir and then, A) start a normal wash cycle and stop it a few minutes after it starts the spray action. Then, open the door and look for suds. B) If you see suds, spray them with Pam spray to knock them down and then C) cancel the wash to drain it out. Repeat ABC until all the suds are gone.
Then, whatever you do, DON'T put dish soap in the jet dry reservoir again!
Good luck
Oct 21, 2014 | KitchenAid Dishwashers
How to fill with liquid to keep glasses from spotting
open door look on the inside if you have a knob beside your detergent door un screw it like a soda cap counter clockwise. Pull out fill hole with liquid jet dry. screw cap back into place clockwise. just snug, not too tight. your cup should be full and dishes spotless. However not all have the jet dry dispensers so you may have to buy the dry variety that hangs in plastic basket on your rack.
If dishes still have spots you may have a water problem that may require a sevice technicians assistance for you.
Mar 03, 2011 | Whirlpool Dishwashers
We have put jet dry and changed soaps but it always leaves a white film on the dishes! No other appliances have problems with this in the house.
Thanks for your question. You may have a couple of problems, first if you are using jet dry it is a surfactant. Which means that it places a small amount of a chemical on you dishes to keep them from spotting. If your dishwasher is releasing to much this will cause a white coating on dishes. In the loading area for you jet dry or liquid spot rinse there should be a knob that is marked from 1-5 or so. First turn this dial all the way down to 1. This will reduce the amount of jet dry released. Then monitor the amount of jet dry that you are going through. You should be able to get about 60 loads from a small bottle of jet dry. The other problem may be that you have washed a item that was not dishwasher safe, like a plastic bowl or such. Some of these items will leech the pigment into your dishwasher and then onto you dishes.
I might suggest that you purchase some dishwasher cleaner from you local Store. Walmart and most box stores carry this in the same section that you purchase your detergent. You will need to empty the dishwasher, following the instructions on the cleaner insert into your dishwasher. Then run it through a complete cycle. After attempting these items please let me know if you still have an issue, but I am almost certain that you will have corrected the problem. Thanks D.R. Wilkins
Nov 05, 2010 | Dishwashers
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Soap not breaking down in dishwasher
Be sure to run kitchen water hot at faucet before starting dishwasher or you will get an entirely cold water washer. Also be sure the jet dry dispenser is not empty. Only use liquid jet dry. Pay no attention if soap says with jet dry. Does not work as well. Hope this helps.
Jan 31, 2010 | Frigidaire 24 in. FDBB840DC Stainless...
Bosch dishwasher leaves water at the end of its cycle cleaned filter and the impeller seams free and not blocked
check for over sudzing. dont use a cascade with jet dry in it. use regular dishwashing liquid and fill jet dry compartment. you can even jet dry level by turning the knob in dispenser.
Nov 12, 2009 | Bosch 24 in. SGS43C12 Classixx...
WHERE DOES JET DRY GO
the turn nob is a cap that you screw out and pour your jet dry liquid in then replace the nob/cap the jet dry will be dispensed automatically.
Sep 29, 2009 | LG Dishwashers
Where do i put jet dry
Check page 2, number 2 in the owner's manual...
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=DC4000&siteCd=MCF
A liquid rinse aid dispenser is only found in select models. Yours may not have a dispenser.
May 16, 2009 | Magic Chef 24 in. DC4000 Free-standing...
Inadvertently put liquid soap in jet dry dispensor of my Bosch dishwasher.How do I resolve it?
you have to take the door apart and dump out what you can and rinse the rest out and reassemble
Feb 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Beaumark jet dry dispenser
Hi puretonedoug,
I'm Harvey the Master Plumber.
Your question is: Beaumark Whisper Wash IV dishwasher jet dry dispenser does not appear to be working ( not using any jet dry) do they plug up or malfunction, if so how do you get it to repair or unplug?
The liquid jet dry dispencer only dispences a few drops in the last rinse. It is not uncommon for it to go a few months before needing refilling so it may not "appear" to be working. Are there spots on your glasses? That's the real test. If there are then just buy the jet dry that comes in a little basket that you hang from the top rack. Replace when it's empty and forget about the auto dispencer. If the glasses are clear then it's working and don't do anything..
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Dishwashers Logo
131 people viewed this question
Top Magic Chef Dishwashers Experts
240cpa
Are you a Magic Chef Dishwasher Expert? Answer questions, earn points and help others
