SOURCE: Need to reset password
OK. I fixed it!
I'm not sure 100% what did it, but think you'll get it to work with the following.
I followed the instructions on how to get the TV set into "test" mode, that were posted by Rotareneg:
http://hardware.mcse.ms/archive144-2005-7-217228.html
(I found these instructions at a couple of sites)
I think that just putting it into test mode resets the password to the default, '000000'. However, I pressed a lot of other buttons while I had the controller open. The only setting I changed (and then put back) while in test mode was on Menu 1. I changed the Program value, which turned out to be just changing the channel.
At some point I realized that I could get all my channels, however, I found that all settings were reset default, including antenna reception vs cable. I change all back and did a celebration dance.
Good luck.
SOURCE: lost password on an acer aspire t180 to get into windows vista
i) when you start ur computer(from the begining of bios screen), continously tap F8 button present on the top row of keyboard(do remember to tap from time you power on your system) and u will some list of option from that select opiton Safe Mode, click on it and u computer boot to the desktop(or u will come asking adminstrator password, donot enter any password directly press the arrow buttongreen and u will enter on to the desktop...)
ii) after entering onto the desktop try click the start button------>click control panel------>click user accounts---->recgnoise the adminaccount and click onit ----->on the left side you will find some option and click on the option remove password, enter the password and u will not be prompted to enter the password......
iii) but if you create an account of your own go ahead create an account thereitself and by keeping password , but do remember the password...
Thanking you
M. Sridhar
SOURCE: samsung impression a877 lost password to unlock
A hard reset will clear everything out of the phone and reset your password. To perform a hard reset on a samsung take out the battery and removve the sim card and power on the phone. when it comes back on type in *2767*3855#. The phone will go thourgh a reset process and when it comes back on take the battery out again and put your sim card back in and power on. It should be completely cleared including the security password.
SOURCE: don't know how to unlock caps lock
There shoudl be a Caps Lock button on your keyboard....look on the left side of your keyboard between the Tab and Shift buttons.
Also, one way to see if your Caps Lock is on is to look on your keyboard, typically in the upper right hand corner and look for a light eminating from your keyboard and it should look like the letter A inside of an image of a palock, if the light is on then Caps Lock is on, just hit the Caps Lock key to turn off.
SOURCE: i was using the default
Default IP address192.168.100.1 Default admin usernameno usernameDefault admin passwordno password
