My monitor is not responding to anything. what can i do aside from rebooting?
do you see the light blinking in the monitor? I mean the POWER led light up? If so, then the monitor is ok and is working good. It is your CPU which has a problem and not sending digital signal for the monitor to display.
Try to turn off your computer. After 3 minutes turn it back on. then notice if you will hear a short beep from the CPU. That signals a successful video initialization. If you went through that process, then your computer will get back to life.
However, if you dont hear a short beep from the CPU, then definitely your CPU is frozen therefore there is nothing to display to the monitor.
You need to open the CPU case, pull out memory modules then plug them back in. Then try booting.
If not successful, try to open case and pull out the processor. Put it back in after 30 seconds. Try booting again.
Do ALL THESE while your PC is UNPLUGGED.
Good luck.
