Question about Singer 7444 Mechanical Sewing Machine
I have read and reread the instructions and have followed it to a t and I can't get the bobbin thread to come up to loop
  • 5,603 Answers
Make sure you pull the bobbin thread out and hold the end while cycling the machine at the start. You need to have a goodly length or it will just not be pulled out.
Posted on Jul 25, 2009
I am having trouble getting the bobbin to function properly during sewing.
It could be the top thread is the problem. Might try removing all the thread. Consult the owner's manual for threading instructions. RAISE the presser foot BEFORE threading the upper thread so the thread will seat properly in the tension disk. Re-thread from the beginning carefully following the instructions--do not miss any spots or thread guides.
If top thread is still creating a mess of loops under the fabric, try tightening the upper tension. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Dec 10, 2015 | Singer 5160 Mechanical Sewing Machine
I can't get the bobbin to thread.
This video may help. Probably not your model, but machines tend to thread and operate similarly.
How to Thread Janome Sewing Machine
Feb 17, 2018 | Janome Magnolia 7330 Sewing Machine
I THINK I've followed every instruction and tip regarding threading my machine and bobbin, but the needle won't pick up the bobbin thread. It just comes up as it went down, without the loop fr
Hi. Usually this is due to a wrong needle or your needle not being set correctly. Do you know if your patcher is a 29k? or?
http://www.parts.singerco.com/IPinstManuals/
There are various manuals at that link... hopefully your patcher is there. good luck
Jul 24, 2012 | Singer Sewing Machines
Keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
The tension on the bobbin is giving big loops and then breaking
This could be one of the following:
  • wrong bobbin for the machine
  • bobbin loaded the wrong way - must rotate anticlockwise when you pull the thread
  • thread not into the tension spring/device on the bobbin holder correctly
  • bobbin wound badly, uneven tension, loose or uneven across the bobbin
  • poor quality or old dry brittle thread could cause the breaking (but the loops is definitely tension issues).
This is a top loading bobbin machine machine and you can download a manual from
http://www.singerco.com/accessories/manuals.html
Here is the threading diagram from the manual.
tally_girl_21.jpg It is important to click the thread down into the tension spring on all top loading bobbin machines and then pull gently on the thread to check that it is under tension, you should feel firm resistance when you pull the thread. If not, then take it out, and try again.
Other thing to look at is how the bobbin is wound. It is necessary to wind a bobbin smoothly and with some tension on the spool as the thread comes off it. Best analogy is the garden hose reel. If you wind it up and don't control where the hose goes onto the reel it will all lump up in the middle, and you won't get all the hose onto it. And then when you go to pull the hose out, it will jam and be difficult to pull. Same with bobbin thread. You want a nice neat even fill across the whole width of the bobbin, not just the middle. To achieve this make sure you use the bobbin winder tension disc when winding. Also use the spool cap on top of the thread spool to stop it from bouncing around as it unwinds - the thread will then wind off around the spool cap and this keeps it running smoothly and not twisting and jerking. If you don't have a spool cap then put the curved handle of a pair of scissors on top of the thread spool to tension it while you wind the bobbin. Also watch the bobbin as it winds, give the thread a nudge with your finger to control the fill onto the bobbin so it winds top, bottom and middle of the bobbin evenly.
I would suggest the following:
clean out the race following the manual directions to remove the bobbin holder, clean in this area, replace it. Wind a fresh bobbin and then load it into the machine, following the manual instructions carefully. Also thread the top of the machine following the manual, put in a new sharp needle from the pack, turn the top tension dial to a medium number (often 5 if dial goes from zero to 10).
Now test sew again. Look at the seam, if you have loops on the bottom of the fabric, underside, then the top thread tension is too loose or not in the top tension discs fully. Generally you should not need to adjust the tension on the bobbin thread for these machines.
Apr 13, 2011 | Singer 5050 Mechanical Sewing Machine
I just bought a memory craft 6600 the thread from the bobbin keeps looping on the top fabric? When I change the tension number it just gets worse Help
Check your threading, especially your bobbin because usually looping on top means the bobbin is not set right, Read your manual,
Aug 24, 2010 | Janome Memory Craft 9000 Computerized...
Bobbin thread does not loop up when threading machine. Then the needle thread get wraped around the inside the bobbin sewing the material to the machine
There are so many thing you need to re-check.
First clean out the bobbin area to be sure there aren't any thread tangles still there.
Open the manual and start from the beginning with threading the machine with the presser foot lever UP - always.
Read the instructions and do not rely solely on the pictures as we all sometimes rush to do (I am just as guilty as the next person to do this).
Make sure the bobbin thread is feeding from the bobbin case in the correct direction.
Hold onto the end of the top thread (after needle has been threaded) and lower then raise the needle to catch and bring up the bobbin thread.
Place the fabric under the presser foot and as you hold onto the ends of the top and bobbin thread, hand walk the first stitch, then use the power pedal.
If you need a manual, you can download (free) from Singer - http://www.singerco.com/accessories/manuals.html
Mar 25, 2010 | Singer 8280 Mechanical Sewing Machine
I need an instruction manual for the Babylock Pro II Model B15
hi!there similar bobbins winder in any brand of sewing machine uses mostly in domestic particularly in industrial manufacturing in this fig.check it out if similar to your bobbins any how itmay be he86acf3a.jpglpfull onethe bobbins winder that was a thread and shoul be clockwise rotation when coming out to bobbins case,if you to wound the thread on your bobbins winder, pull threads on spool then wind this in several times 4 to 6 rotation clockwise loop thread on top machine there is bobbins winder disc for tension put winder bobbins on shaft winder near hand wheel push the latch against bobbins winder to fit thead run machine to wind the thread.After hread wound in bobbins winder cut thread and insert winder to bobbin case as shown.
insert bobbins to shuttle hook case under needle foot holder
lift the cover plate you can see under this is the shuttle hooke415486.jpgafter set up was made on bobbins thread,set also the upper loop thead beginning at top of machine start on spool, pull thread and loop to upper disc tension then to the slot portion as in figure
insert on lever dial goes to the needle adjust tension to #8 range to #12 for cotton fabrics two layer sewing.
Mar 17, 2009 | Baby Lock Sewing Machines
Tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
Feb 27, 2009 | Brother ES2000 Computerized Sewing Machine
Singer 7444 Mechanical Sewing Machine Logo
114 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
