Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
After about 30 to 40 minutes of use (varies, the
I have a Simplicity Citation with a Briggs 23 HP Vanguard engine. After about 30 to 40 minutes of use (varies, the engine acts likes it would if being choked (pulling up on the choke does nothing). After the mower sits for a moment, it will mow for another 10 to 20 minutes (varies) it will do it again. HELP!!
The mower was services at the beginning of this season. The mower is nine months old.
I have a 7 year-old craftsman mower with a 22 HP Briggs engine that has the same issue. After about an hour, the mower acts as if it is starving for fuel and then stalls. Then after about 5 minutes of sitting, it will run for a little while longer.
If your engine is similar to mine, then its carb has a fuel shut off solenoid which shuts off fuel to the Main Jet when Voltage is removed to prevent backfiring when the key is shut off.
Unfortunately, this solenoid can also cause the carb to starve for fuel when not working properly. In my case, when I cleaned the solenoid and the solenoid's connections, the tractor had no problem after that.
Hope that helps,
Steve
Posted on Aug 02, 2009
Vanguard backfires through carb
If you say the valve stems were bent..first did you find out what bent them they just bend...and is the valve face seat damaged..if they were not...your engine is out of time or you did not set the valve stem lash when replacing them this allows the intake valves to be open slightly under the firing stroke firing back through the carb and intake...you should have around four thousands of an inch clearance when the springs are completely relaxed and and you should be able to wiggle the valve rocker tappits ...check that if they are correct your engine is out of time..good luck
Oct 10, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
16 hp vanguard surges at idle
Sounds like your carb float valve and/or needle is dirty causing the float inside the bowl to raise and lower instead of staying level when the gas is flowing into the bowl ..while at higher soeed gas is flowing and used up as needed but idle gas to the carb varies..and causing surge. Clean or rebuild is in order..good luck
Jun 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Have a 23 Vanguard on a mud boat and when engine damp from dew or fog, engine turns over but will not start. When engine dries, starts right up.
Your coil may be getting damp or wet..try using a plastic bag over the coil..or use some spray that will keep the damness out..good luck..
Jan 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and...
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Sep 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I am considering purchasing a used Exmark with a 23 HP Vanguard engine (~70 hours on the engine). I've not been too pleased with Briggs (have one on my John Deere garden tractor - hot natured and...
yep its a briggs and normaly there very good ploders
if your john deere spluters and back fires it needs a good looking at check the valves first,,,a hand full of bolts and the heads off and if your carfull you can still use the same head gasket again,,,also check the carb there very finiky and need to be kept clean the air filter is a joke,,,but clean it anyhow and they like new plugs,,,every ten years or so? iv worked on 100s of brigss and stratons/vanguard. there good engines but there ploders not sprinters there ok in a tractor but no good in a tank there to darn slow
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Oil in air breather
sounds like you have too much oil in the engine (should normally be around 500-600ml when there is too much oil, it gets past the piston rings and pushes it through to the head.
May 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
1,153 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
