Question about Refrigerators
How do I hook up my water inlet value to my ice maker for Whirlpool
    Champion:
  • 363 Answers
Any homedepot or lowes has a water supply kit in their plumbing dept. The directions are on the package
Posted on Jul 26, 2009
Hello I have a whirlpool side by side model # ed5jhaxml00. The ice maker stopped working, I still have water in the door. I replaced filter and is still not working. Any Ideas?
American Appliance
Hard to know exactly without being there on the spot but the link will provide good information on how they work. Your fridge also has a dual water inlet valve. The door can provide you water while the ice maker can not receive water because of the second inlet valve.
Whirlpool W10408179 Water Inlet Valve AppliancePartsPros com
Jan 15, 2015 | Whirlpool Refrigerators
My whirlpool ed20db ice maker isn't making ice. Inlet tube is frozen solid
Thanks for the model number. The water control valve=> W10245167 Water Inlet Valve will need replaced when this happens. Problem allows water to leak slowly into the ice maker and fill tube can become solid very quickly, or very messy ice formations coming down from ice maker, Thanks John Tripp Appliance 911
Jan 28, 2014 | Whirlpool Refrigerators
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
Ice maker has stopped making ice
most likely a bad water inlet valve located in the back of the ref where the water line hooks up at
Nov 18, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hooked up water to icemaker, but it is not filling with water. Bought used; 3 years old.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen and then refils. If there is ice, lift the cut off arm and let it drop to see if it will start.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Dec 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Auto Ice maker in Whirlpool fridge, not producing ice. I suspect the water feed line might be frozen since it was working fine two days ago. I haven't heard the water fill and the tray is empty.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Oct 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Slow water to the water disper ice maker ok changed water inlet v
You could check and replace the filter, it could be clogged
Jul 17, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker not working -
If the inlet in the freezer is frozen then the water valve is leaking. Replace the water valve.
Feb 13, 2009 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
