Question about Garden
What is the proper fuel mixture for a husqvarna chain saw ?
  • 398 Answers
The Correct Fuel Mixture Ratio
All two stroke engine will use a 50 to 1 ratio using today's two stroke oils. I once used an old chainsaw probably from the 1960s, that had a sticker on it that said to use a 25 to 1 fuel/oil ratio, but that would have been using two stroke oils of the time period the chainsaw was manufactured. In that chainsaw I used 50 to 1 ratio with no problems. Today's two stroke oils compared to yesteryears are more efficient at lubricating. It is like comparing today's synthetic motor oil to motor oils of decades ago. All the equipment I use in landscaping, anything from a weed eater, leaf blower, chainsaw, hedge trimmer, use 50 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 liter fuel can and use it in all of the equipment for my customers and for my landscaping. To calculate the ratio is simple. For instance , if you have 1 gallon of fuel it is best to break it down into smaller units, like ounces. One gallon = 128 oz. You then divide this amount by the ratio of the mixture which is 50 to 1 (50 parts fuel, 1 part oil). So therefore 128 oz of divided by 50 = 2.56 oz (you would just measure out 2.5 oz ) of two stroke oil. If using metric, say a 5L gas can, you would break this down to smaller units, which would be milliliters. 5L = 5000 ml. 5000 ml of fuel divided by 50 = 100 ml of two stoke oil.
Posted on Jul 25, 2009
  • Phil Sartori
    Phil Sartori Sep 20, 2013
    Thanks Bill! phil
  • 691 Answers
All two stroke engine will use a 50 to 1 ratio using today's two stroke oils,
  • 61 Answers
Best bet would be to find your manual online: http://www.husqvarna.com/us/homeowner/support/download-manuals/
Some of the newer ones have a separate oil tank, so no mixing required.
dontbother10
  • 2220 Answers
SOURCE: Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 25, 2009
dontbother10
  • 2220 Answers
SOURCE: What is Fuel Mixture Husqvarna 455 Rancher Chain
Duplicate post Close/delete
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
dontbother10
  • 2220 Answers
SOURCE: looking for fuel mixture for Husqvarna chain saw.
Fuel/Oil Mixture
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Oct 03, 2009
dontbother10
  • 2220 Answers
SOURCE: How do I adjust the mixtures?
Is this helpful?
Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
The "L" adjusts acceleration and smooth running. The "H" adjustment is almost completely how it performs at full throttle (should be adjusted for performance in a cut IMO). HTH
Lou
Posted on Dec 13, 2009
Testimonial: "I'm jumping the gun here, because I haven't had a chance to put your advice into action, but that's exactly the sort of info I need. Thank you!"
I need to know the correct fuel ratio for a Huska Vona 235 chainsaw
50:1. Your manual is here.
[PDF]OM, 235 e/ 240 e, 2008-02, Chain Saw - Husqvarna www.husqvarna.com/.../HUSO%2FHUSO2008_USen%2FHUSO2008_USen_O08020...
  1. Cached
235e 240e. Operator's manual .... You will find the following labels on your chain saw: ..... recommended (a lean mixture may mean that the fuel lasts longer than ...
http://www.husqvarna.com%2Fddocdownload%2FHUSO%252FHUSO2008_USen%252FHUSO2008_USen_O0802031_.pdf&usg=AFQjCNHmUdP3dUYTbfqmTs7Z7SATwGd1Nw
Jan 23, 2017 | Garden
Fuel mix
The oil ratio is 50:1
Here is the website: http://homeguides.sfgate.com/oil-fuel-mixture-farm-tough-husqvarna-chainsaw-83933.html What Is the Oil Fuel Mixture for Farm Tough Husqvarna Chainsaw
Aug 19, 2014 | Husqvarna Chain Saw Handle Models 362 365...
254 husqvarna chain saw mixture and plug gap
Plug gap 0.5mm, fuel oil mix 50-1 with Husqvarna two stroke oil, or 25.1 with other makes of two stroke oil as the quaility is not known
Jun 14, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the recommended oil/fuel mix for Husqvarna 136 chain saw please?
40:1 is the recommended mixture for husqvarna chainsaws. Use husqvarna 2 stroke oil rather than the cheap types you get at car service stations as they will not protect your saw like the good quality oil.
Nov 24, 2010 | Husqvarna Garden
No problem; using a borrowed Husqvarna 44-don't know fuel mixtures (if any). The chamber for "oil"-is that engine oil (if so, what do you recommend) or chain saw oil (if not, is there another...
The mix fuel mix is 40:1. Use Husqvarna 2 stroke oil not the cheap stuff on sale at car service stations. The chamber for oil is for chain oil which can be bought at most places that sell or hire machinery like chainsaws, lawnmowers etc.
Nov 14, 2010 | Husqvarna 44" Chainsaw Bar Fits Jonsered...
Amt. of oil to replace at change in Husquavarna chain saw model CRT53
Chain saws don't require oil changes--the bar oil is 'constant loss' from the oil tank while running--just top up the tank before and during each use. Husqvarna does recommend draining and cleaning fuel and oil tanks before storage (not sure how many folks pay attention to this). The fuel mixture is also 'constant loss', so there is nothing there that requires changing--just be sure to use fresh fuel and always shake the container before adding to the saw to make sure the saw oil is properly mixed. Hope this helps!
Oct 04, 2010 | Garden
What is the oil mixture for husqvarna chain model 235
50:1 fuel to oil ratio is correct for this saw. Be sure to use modern synthetic saw oil, not a petroleum product like outboard motor oil. Premix the fuel and oil in it's own can, and shake thoroughly just before filling the saw each time. With these modern fuel/oil ratios, serious engine damage can occur if not thoroughly mixed each time. Hope this helps!
Sep 05, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
8,099 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
