Question about Microwave Ovens
I have a Kenmore Microwave Oven - Elite Series - only about 3 years old, keeps blowing fuses - any advice on what might be the problem? I think the first fuse blew during a power outage, not sure if that had anything to do with it, but when I replaced the fuse it blew again just after turning the oven on for about 3 seconds.
    Novelist:
  • 103 Answers
Make sure you have the oven plugged into a designated outlet...what I mean by that is...the outlet your plugging your oven into must be wired right to the fuse box by itself...because the oven will take most of the power from that one fuse for itself...also make sure the fuse is rated for what the oven needs....on the back of the oven, it will tell you how much current it takes...(???Amps), if it says 12 amps for example...the fuse should be 15 amps...if its lower that 12...it will keep blowing....if all of what I said check out then your oven has developed a short circuit...most likely the high voltage diode or magnetron....have it serviced....
Posted on Jul 25, 2009
My Kenmore elite built in microwave oven model 790 488 03100 has stoppped heating what can i do
It may be a bad fuse or capicitor. I have had a time in the past with something similar. I contacted Repair Clinic.com. They were very helpful with their advice and even followed up to make sure I got things fixed okay.
Dec 09, 2014 | Kenmore Microwave Ovens
Have a TE code showing on my kenmore elite microwave hood combo
At some place I saw that the TE error refers to the touch panel.
If you go to http://www.searspartsdirect.com/ and enter your full model number you can get parts list and buy parts and even get repair advice.
Link below shows how to replace a control panel on some model of microwave oven. In the video you will see a ribbon cable being removed. You might want to wipe the contacts of the ribbon with alcohol and put it back in to see if it helps with your problem.
F3 error Microwave oven control panel replacement
Sep 11, 2014 | Kenmore Microwave Ovens
Kenmore 401.80082700 Over the range microwave just stopped working. WILL DO NOTHING! Is anyone home out there?
I would go ahead and replace the microwave oven the cost to repair will be higher than what you are thinking of getting.
Mar 23, 2012 | Kenmore Microwave Ovens
3 year old OTR microwave left on with nothing in it. now shows no power,board,lights or fan. what do I check first?
You have to open it up and see if you can find the power fuse, usually a BUSS 15amp Slo Blo that protects the Microwave Tube from drawing too much current and causing a fire. These fuses degrade over time or some get through that are not quite 15 amps and blow.
Dec 19, 2010 | Kenmore 69642 Microwave Oven
Need to replace broken glass plate for kenmore elite microwave model number 565.61584011
The tray used to be part number 16264 but it's no longer available.
That model oven was made by Sanyo.
If you have the old one, you can contact Martin Microwave with the dimensions and they may be able to find a suitable replacement.
Jul 02, 2010 | Kenmore 63792 Microwave Oven
Kenmore elite countertop microwave/convection oven
Time for a new cover plate or a new microwave. Depending on the age of the unit, the part may not be available anymore.
Jul 06, 2017 | Kenmore Microwave Ovens
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
I believe mine blew a fuse as well
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
many people have been electrocuted with an unplugged microwave due to the enormous residual charge inside.
you can now get a new microwave at walmart for fifty bucks..........why monkey with a ten year old unit.
Aug 17, 2009 | Sharp R-963 Convection/Microwave Oven
Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
May 23, 2009 | Microwave Ovens
Owners manual for Kenmore Elite Microwave Model 66462
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgcaab351.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Jan 18, 2009 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave Ovens Logo
128 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
