SOURCE: oasis elite washer lid locking mechanism broken
go to repairclinic.com to find the part. Have the make and model ready, and you have a good chance of finding the part there.
SOURCE: Cinego D-1000
Well I was hunting for a replacement remote, came across this page, and know this fix for you all. Go into your setup menu, slide over to the management tab and make sure Auto Source Select is checked. If it is not, it does not search for a DVD but instead looks for only external inputs. Even pushing the manual source select button will not find the DVD if this entry is not checked.
SOURCE: connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
SOURCE: Broken flash drive
The problem you're having is unfortunately common. There are some brands that tend to hold up better, including a mini hard drive version by IO Magic(bout $30 for 12GB) they tend to have retractable or foldaway usb plugs which makes them less suseptible to that kind of damage.
As for fixing them, it's nearly impossible to repair them permanently but I can usually get them up and running long enough to grab your files and get them to a DVD or new drive.
I just signed up here a couple days ago and am unsure of the rules about offering services but if you're interested get back to me and I'll see what I can do(repairs generally rune $50-$120, depending on type of damage)
Hope this Helps,
Chris
Armor-IT
SOURCE: cracked thule storage box-want to fix it-How?
Use Devcon High Strength Plastic Welder Epoxy for Vinyl, PVC Piping, Fiberglass,etc. Line up the broken area as best you can and apply the mixed epoxy on the interior side as well as the exterior side. Do not overwork. It gets stick and lumpy fast. Apply it while it's smooth. With this epoxy you have about 5 to 7 minutes before it starts to get real sticky. Use the edge of a thin cardboard box to apply. I used a piece of a cardboard nail box I had laying around. Don't use your good puddy knife because you'll never get it clean. Let it dry - about 15 minutes. Do the process again until you've got it covered well and as smoothly as possible.
Don't be alarmed as this epoxy is a creamy color. After the epoxy has dried, use a fine sand paper to sand it off. Wipe the sanded area clean with mineral spirits. Then use a glossy black spray paint to touch it up. Coat it with the spray paint several times while letting it dry in between sprays. It won't be perfect but it will be waterproof.
