I opened up my settings on my MXQ pro 4k tv box and changed the security settings hoping this would keep my grandchild from accessing fb from the tvbox. once i made the changes, selected a pin # and selected which apps to allow access. i lost all my kodi add ons, most of my settings options. there is nothing showing in kodi but the memory usage shows the same.
SOURCE: Accessing External Inputs Settings
you have to use the remote control for the tv not the dvr.
the dvr control likely cannot control the tv inputs programming unless you can program the correct code. and most new lcd panels don't have the correct codes for existing remotes
access using ext on the tv remote.
you may have to go into the menu and tell the tv what the ext is set to ie.. a channel or a input.
SOURCE: unable to change application settings in my nokia 6233
DO RESTORE SETTING OF UR PHONE THEN TRY AGAIN IT SHOW SAME PROBLEM
REMOVE MMC BACK UP OF ALL UR DATA FROM PHONE MEMORY INSTALL NOKIA PC SUITE IN UR PC AND DOWNLOAD UPDATES FOR UR MOBILE FROM NOKIA.COM INSTALL IT AND UPDATE UR MOBILE ONLINE.IT WILL FORMATE UR MOBILE ,RESET UR ALL UR SETTING
SOURCE: port forwarding tg782t to allow remote desktop
your firewall might have an Intrusion Detection System (IDS) which locks your network if programmed to detect unwanted ports. Work on your firewall first. hope this helps..
SOURCE: cannot add new access point on my nokia3110c
when i try to add a new access point on my nokia 3110c through personal configuration settings a message appears saying 'cannot add new account,memory full'.I've tried restore factory settings but no use........plz help me
SOURCE: i have not use the
hi everyone , my name is karthik
to use internet by nokia 3110c as a modem , you must activate any internet packs to use freely , then follow the simple steps ,,
step one
open menu -----> settings-------> configurations -----> default configurations ---> ( all the configuration setings will provided by the mobile operators )---- select your operator from the list
step two
activate the configurations of your operator ----------> activate default in all applications > select the preffered access point ------------- done now you are able to use internet on your pc and mobile ,,,
you do not need any personal configurations to use internet
if you have any doubts you can contact me personally at [email protected]
