Benq monitor keeps auto adjusting over and over. help!!!
    Sergeant:
  • 168 Answers
The problem may be that the computer video is on a setting that is out of range for the monitor. To quickly test this, boot to the setup screen. If it is ok, that is your problem. If it still keeps auto adjusting, there is probably a bad component in the monitor. If possible, try it on a different computer. If bad, you will most likely find that replacement is less expensive than repair.
Posted on Jul 25, 2009
damanpreet_c
  • 69 Answers
SOURCE: problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Posted on Nov 06, 2008
SOURCE: computer monitor keeps auto adjusting screen
I don't know if this solution is credible to all monitors with this problem.... but have a gateway monitor and it kept doing that annoying "auto processing" flash while i worked...but i figured it out...for some wild reason i held down both the "auto" button and "contrast down" button and it fixed it. it will take a couple of tries but on a lucky push I did it and it went away and i havent had a problem since...I hope i have been a little help :)
Posted on Feb 03, 2009
  • 172 Answers
SOURCE: Auto Adjust keeps popping up
Is this a computer moniter or a tuner/tv
Posted on Aug 11, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a BenQ FP71G+ 17 lcd monitor
When you have strange problem like this, first place to look will be the power supply section. Look for burnt parts, leaking/bulging caps, that will be the starting point.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 20, 2010
  • 732 Answers
SOURCE: I have a BenQ FP71G+ monitor and the auto adjust
radioactivet, A qualified technician will need to investigate the units "switch-mode-power-supply" for typical "faults" and locate the faulty (bad) component(s) that ma be causing monitor to act this way. "Noise" on the +5 volt DC rail going to the vga/lcd interface (processor) may be why display is acting "strange" with uncalled for pop-up's appearing!! That's the very first place I would investigate when dealing with ANY COLD-CATHODE-FLUORESCENT-LAMP, BACK-LIT LCD DISPLAY. 12fixlouie
Posted on Jun 04, 2010
My monitor keeps opening monitor menu and keeps auto adjusting
As you have already used a cleaner spray, this is a sign that the monitor is on its' way out. I had one that went the same way.
Apr 13, 2013 | Computers & Internet
Stop auto adjusting of monitor/screen. the screen keeps on auto adjusting... how do i stop it?
Make sure your resolution is set to the native resolution of the monitor. In this case, 1280x1024
Mar 01, 2011 | BenQ FP72E 17" LCD Monitor
Benq T52WA LCD MONITOR SMPS OUTPUT VOLTAGES?
Hi
My Benq t52wa wide screen monitor works fine for some time and then its goes off for a few seconds and then comes back in regular intervels. This keeps on happening. Also im unable to get the auto adjusting thing that comes on the screen to go off. IT keeps adjusting.
I checked for the drivers and it says all drivers are up to date. Any suggestions please?
Feb 13, 2011 | BenQ FP553 (White) 15" LCD Monitor
Hi, my BenQ FP72G 17 inch LCD Monitor keeps auto-adjusting every 5 seconds and every now and then it will turn itself off and later go on again. Any help ?
Make sure the cables are in well with a good amount of slack, it can cause a problem if your power cable or computer to monitor cable is loose
Jun 30, 2010 | BenQ FP72G (Black, Silver) 17 inch LCD...
May 20, 2010 | BenQ FP71G 17" LCD Monitor
Aug 02, 2009 | BenQ FP71G 17" LCD Monitor
Computer monitor keeps auto adjusting screen
I have a Benq that was continually auto adjusting, I used electronic cleaner spray on all the controls (a good spray) and now there is no problem, suspect the controls were sticking, especially the on/off and the auto adjust button
Dec 20, 2008 | Computers & Internet
Benq screen resolution auto adjust seems to auto adjust wrongly
I would recommend you to bring it back and get a new one, if its till under warranty. You cannot fix the problem on the panel buttons it looks something to do with the components in the circuit bord.
Nov 19, 2008 | BenQ FP731 17" LCD Monitor
Computers & Internet Logo
1,557 people viewed this question
David Payne
David Payne
