Question about Sharp R-1480 Microwave Oven
Need a slim over the range microwave
I an over the range microwave that is 14 inches high or less, preferably stainless steel or black. I can't find one anywhere. Do you know of one?
Julie
  • 398 Answers
Matag can sell you one call them and give them your size....
Posted on Jul 25, 2009
Need a manual
more information would allow more precise answers but here is one manual
SMH9207ST 1100W 2.0 cu. ft. Over-the-Range Microwave (Stainless Steel) http://downloadcenter.samsung.com/content/UM/200911/20091106160308468/SMH9207_XAA-03686A-03_EN.pdf
Oct 04, 2015 | Samsung Microwave Ovens
How to replace a the control board on a Samsung microwave
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
See my profile picture if you need more help.
Apr 25, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
Turntable in new Samsung Microwave is wobbly-- turns OK but goes down if you put something on it away from the teflon rollers.
If the turntable is unstable in the oven, it's most likely an issue with the oven cavity. The tray is probably borosilicate glass, the roller guide is simple, this is something a service tech should see in person. If the oven in still under warranty you should pursue a warranty service call to make sure the oven cavity was not stamped incorrectly. Pleazer Appliance...
Jan 13, 2015 | Samsung CHEF Collection 2.1 cu. ft. Over...
Do i need a special vent kit to vent microwave to outside
Yes, an adapter/kit should have come with the unit and then you would have to buy the piping etc.If you do not have the adapter/kit get it from the manufacturer or unit seller.
Sep 12, 2014 | Samsung 2.0 cu ft Over-the-Range Microwave...
Fan will not stop
fan is normally controlled by a microswitch which can be accessed by removing top cover, you may have to replace the microswitch but this should only be carried out by a licenced electrician as high voltage is involved
Apr 21, 2014 | GOLD STAR LLC MV1611ST 1.6 cu. ft. 1000...
I want to change the handle to stainless steel to match my new Whirlpool Black Ice range that has stainless steel handles so everything will match, please HELP!!!
A suggestion---call or contact LG to see if what you want is even available---only other (a little crazy) is consider if metal having the handle removed and chromed.
Nov 08, 2012 | LG LMV1630ST Microwave Oven
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Making a loud buzzing noise.. not heating.
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Jan 28, 2011 | Whirlpool WMH3205XVS Stainless Steel 1000...
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Sharp R-1480 Microwave Oven Logo
4,505 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
