Back to:
Tags:
Lexmark Color JetPrinter Z25 InkJet
Lexmark z25 drivers for windows vista (by 69 users)
posted by romoromo on Nov 21, 2007
i have recently upgraded to Windows vista and tried to install Lexmark z 25 drivers, and it did not work? any solution to this problem. the printer was working well on Windows xp.. and other compatible drivers can be used to install on windows Vista? Please give suggestion
Comment by romoromo, posted on Nov 29, 2007
Hi seajade,
The link you gave worked. and can print now with Vista. Thanks a lot.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
68 Other Users Have The Same Problem
Comment by Guest, posted on Oct 19, 2008
to install driver in window vista for printer
Comment by Guest, posted on Oct 11, 2008
HOME
Comment by lady_hawk102, posted on Oct 07, 2008
i have a lexmark color jetprinter z25 and i have tryed to find a driver and couldn't it is not compatable with windows vista. I have a compac computer with windows vista and hp.
Comment by lizi801, posted on Oct 04, 2008
I have tried to install the lexmark z25-z35 on my new dell laptop with windows vista. Vista picks up the driver but when it says it's complete it still fails to print. I tried to install with the disk as well but that too does not work?
Any advice?
Comment by jolandi, posted on Oct 01, 2008
I cannot find a vista driver for my Lexmark Z25 printer
Best Solution
posted on Nov 21, 2007
FixYa! (100)
SeaJade
Rank:Guru Guru
Rating: 85%, 159 votes
Hi, There do not as yet appear to be any drivers around for Vista for the Z25 but I have made some enquiries and am waiting on answers. Will let you know ASAP when I get a reply.
Comment by SeaJade, posted on Nov 23, 2007
Hi, I have got a link for you to go to to download the appropriate drivers for use with your printer on Vista operating system.
Hope it all works well for you, let me know how you go
Link is:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=15:1:0:337:0:0&searchLang=en&os_group=WinXP
SeaJade
P.S download the custom driver
Rating Locked! (?) romoromo has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on lexmark z25 drivers for windows vista:
I don't want to Accept this solution
Solution #2
posted on Apr 01, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
throw printer away buy new one
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
posted on Jan 13, 2008
Helpful (85)
Guest
Rating: 0%, 0 votes
The 'solution' offered at the above download does not work with VISTA. I haven't been able to find drivers for the Z25 Lexmark and Lexmark tech people say they won't be providing one...the printer was a cheap, cheap printer ($20 at Walmart) so you're gonna have to buy a new printer for your Vista system
Thank You!
Solution #4
posted on Jul 02, 2008
Helpful (85)
pricsilva
Rating: 85%, 2 votes
After installing the driver from the CD, I was only able to print by doing the following change on Control Panel.
1. Lexmark Z25 printer Properties
2. Ports tab
3. Select USB00x instead of LPT1
Hope that helps,
Priscila
Thank You!
Solution #5
posted on Jan 27, 2008
Helpful (85)
tc_123
Rating: 83%, 9 votes
I found this solution on the mrdriver.com website... and have been able to successfully print on my z25 printer on my new vista computer... The original person asked about the z35, so I'm assuming it works for either...
I hope this helps!
________
1) Go to Control Panel > Printers
2) Right-click your Lexmark printer and go to Properties
3) Go to Advanced tab
4) Notice where it says Driver: and then shows your Lexmark printer. Mine said "Lexmark Z25-Z35". When I click on this drop-down list I had another available driver below it called "Lexmark Z25-Z35 Color Printer".
5) Choose "Lexmark Z25-Z35 Color Printer" if it is available.
6) Click Apply
7) You may have to finish a few more installation steps. I had to, but it only took a minute and I had my printer working!
Thank You!
Solution #6
posted on Nov 20, 2008
Not Rated (0)
stephyes
Rating: 0%, 0 votes
i need the instalation driver for this printers window vista
Thank You!
Solution #7
posted on Jul 12, 2008
Not Rated (0)
MaxExpert
Rating: 0%, 0 votes
I followed solution # 2 but my Z25 can only print kind of pale now and very slow if "best" is used. I does not recognize the black cartridge either. Looking for more support and a good working driver.
Regards,
George.
Thank You!
Solution #8
posted on Jun 11, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
WHAT DO I DO AFTER I DOWNLOADED THE DRIVER? I HAVE DOWNLOADED THE DRIVER PROVIDED IN THE LINK..HELP PLEASE
Thank You!
Can you Help with these Printers problems?
Ink cartridges seem full, fairly new, but text prints...
hi i just installed windows vista. my flatbed scanner no...
My Lexmark Color JetPrinter Z25 InkJet-usb connect, wants...
the printer comes on but will not print, someone said it...
naunahan mo ako dito bok hehe...
68 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Sep 30, 2008
lexmark x63 will not print with windows vista
Comment by holly j, posted on Sep 03, 2008
I do not have the program to the printer at all but i have tried to find others on the internet and they do not work with windows VISTA.
Comment by Guest, posted on Sep 02, 2008
I have downloaded a couple of drivers but I can't use my Lexmark z25 with vista.
Comment by anastacey, posted on Aug 28, 2008
I i have tried a couple different downloads for a driver for my printer. i have a lexmark Z25. I have windows vista. my email is dragoncowgirl@hotmail.com. if anyone finds out something please let me know
Comment by Guest, posted on Aug 26, 2008
i also have the same problem with my printer lexmark z25 not compatible with windows vista.Any suggestion pls? Thanks
Comment by juliem904, posted on Aug 25, 2008
Hi I just bought a lexmark z25 and it is not compatible with Windows Vista can you help me??? My email address is juliem904@yahoo.com
Comment by Guest, posted on Aug 11, 2008
printer not compatability with vista
Comment by jonnielow, posted on Aug 08, 2008
no start up disc
Comment by Guest, posted on Jul 31, 2008
no me funciona la impresora lexmark z25 con sistema operativo vista
Comment by Guest, posted on Jul 29, 2008
lexmark x84-85 drivers for windows vista
Comment by walipear, posted on Jul 18, 2008
I cannot find my disc and just got new vista Can you help me install so I can use my Lexmark z25 printer.email address walipear@msn.com
Comment by Guest, posted on Jul 03, 2008
I have
Comment by Guest, posted on Jun 26, 2008
need help getting printer info instllrd into computer
Comment by Guest, posted on Jun 15, 2008
Same problem. Did not see a link to go to for the fix.
Comment by crazyduck90, posted on Jun 12, 2008
what do i do after i dl the drivers
Comment by c8nme, posted on Jun 08, 2008
what is the link so that i too can get my vista system to print with the lexmark z25
Comment by bluemess, posted on Jun 06, 2008
hi i got a problem because my laptop is windows vista basic and i couldnt work my lexmark z25 printer, any help where can i find a right software plss
Comment by crazynorton, posted on May 31, 2008
no disk to install a lexmark z25
Comment by Uprising, posted on May 31, 2008
Have Lexmark Z25, can't find Vista drivers, pls help
Comment by Guest, posted on May 13, 2008
have emachine computer with windows vista. lexmark z25 will not install and need driver for printer to work
Comment by kimberly26, posted on May 10, 2008
I can not install my lexmark z25 inkjet printer to my computer whish is running windows vista any free downloads???
Comment by nesha poo, posted on May 08, 2008
I am trying to download the lexmark z25 without the cd with an windows xp program and I am not figuring out how to download it.
Comment by Guest, posted on May 08, 2008
cant installer lexmark printer z25 for my vista, please help me.
Comment by Guest, posted on May 06, 2008
I too have the same problem my lexmark z25 works well on xp but not visa home basic . what do I do? thanks
Comment by yacov_dabbac, posted on May 04, 2008
I have lexamark z25 that work very well with os xp I UPGRADE MY OS WITH VISTA HOME PREMIUM MY Z25 DID NOT WORK WITH VISTA WHERE I CAN FOUND A DRIVER
Comment by Guest, posted on May 04, 2008
i have some problem i chnged from xp to vista home premium where i can find a driver for vista home premium
Comment by Guest, posted on Apr 30, 2008
will not print, all new cables, I can copy and the fax rings so there is communication. I have new computer and it worked great prior
Comment by Emah, posted on Apr 27, 2008
I have a Lexmark Z54 Printer, and cannot get the drivers from Lexmark that will enable me to use the printer. Can you help? I have been to the Lexmark site, they do not have compatability with Vista OS.
Comment by Guest, posted on Apr 27, 2008
had a lexmark z35 given to me and need drivers i run vista
Comment by Guest, posted on Apr 22, 2008
Need a driver for Vista
Comment by Guest, posted on Apr 17, 2008
I have a Lexmark Z35 printer and my computer uses Vista. Need HELP
LJF
Comment by Guest, posted on Apr 16, 2008
i have a printer that is z25. but it doesn't work in windows vista...so do anybody have lexmark z25 drivers for vista operating system,thx..
Comment by Guest, posted on Apr 08, 2008
lexmark x73 dos't work with windows vesta
Comment by Guest, posted on Apr 03, 2008
My lexmark z25 won't work with my new computer with windows vista
Comment by Guest, posted on Apr 01, 2008
printer just wont work
Comment by Guest, posted on Mar 30, 2008
Comment by Guest, posted on Mar 25, 2008
I HAVE SAME PROBLEM
Comment by jonny36, posted on Mar 23, 2008
lexmark color jetprinter z25 inkjet dose not work with vista?
Comment by brn_duh, posted on Mar 23, 2008
my printer lexmark z25 doesn't seem to work vista. i recently bought a new computer. and was force to upgrade from xp to vist. the printer workes with xp. what can i do?
Comment by Seanus, posted on Mar 11, 2008
just got new computer which has Vista pre loaded. Cant find my Lexmark z 25 set up disk. Any help would be appreciated.
Comment by Cowgirl007, posted on Mar 09, 2008
My computer has Windows Vista and the Lexmark Z25 will not install on it.
Comment by Guest, posted on Mar 02, 2008
my printer was working with windows xp and now not working with windows vista. Lexmark Z25-Z35
Comment by dully1, posted on Mar 01, 2008
is there a new solution or driver for the lexmark z23 i have the same problem, but was told by lexmark that no driver is a available for vista home premium, looks like a bin job. but it is old, any recomendations for a printer thats economical and easy for me to refill cartridges all in one perhaps.thankyou, dully1
Comment by Raider6531, posted on Mar 01, 2008
I need a link to a windows vista driver for my lexmark Z25
Comment by glosa, posted on Feb 27, 2008
i also have the same problem installing my lexmark z25 printer on my windows vista i been trying for days and it won't install. please help glo
Comment by Guest, posted on Feb 26, 2008
i ve bought a new lap top which has windows vista on it, but i tried to install Lexmark z 25 drivers, and but it didn't work.would you please find a solution to this problem. the printer was working well on Windows xp..
thank you!...
Comment by marleneee, posted on Feb 15, 2008
i have the same problem can somebody help me? please where i can get the link the help u ?
Comment by Guest, posted on Feb 14, 2008
error encountered when vista trying to install software from original disc supplied wen printer purchased advice was contact manufacturer
Comment by hamochick_13, posted on Feb 04, 2008
i plugged the printer in but it says i need to install it but i cant and i recently upgraded to windows vista
Comment by adam narvaiz, posted on Feb 02, 2008
Comment by Guest, posted on Jan 28, 2008
I just got windows vista. I tried to hook up my Lexmark Z25 printer to it. I don't have the set-up disc anymore either. Windows can't install it. Is there anyway to install the printer?
Comment by Guest, posted on Jan 05, 2008
i receive the same error
Comment by plilip, posted on Dec 31, 2007
i have the sema promblem with my printer ''lexmark z25''
please help
Comment by horus1101, posted on Dec 30, 2007
Please help me find a solution. I can not print in my previous printer. Thanks in advance for your help for I have tried in many ways to sove this.
Comment by Guest, posted on Dec 28, 2007
i have recently upgraded to Windows vista and tried to install Lexmark z 25 drivers, and it did not work. any solution to this problem. the printer was working well on Windows xp.. and other compatible drivers can be used to install on windows Vista. Please give suggestion!
Comment by cst2u, posted on Dec 25, 2007
hi. i have a notebook with window vista and i try to install lexmark z25 driver and it did not work. Pls help. Thank you. KKY
Comment by Guest, posted on Dec 24, 2007
I have recently bought a new laptop using windows vista and i can't find a dirvers for windows vista for my lexmark z25 printer. pls help. thank you
Comment by deedeem, posted on Dec 12, 2007
Comment by benissim, posted on Dec 09, 2007
my lexmark z25 doesnt work in my pc , is a new pc i bought 6 months ago and i have vista, what wrong
Comment by Kamruzzaman, posted on Dec 05, 2007
Comment by Guest, posted on Nov 28, 2007
Exactly the same problem. Tired to download a driver that wat said to be appropriate, did not work. I cannot believe that Lexmark just does not care enough. Admittedly, this is a cheap printer, but the cost of ink cartridges s should give Lexmark enough incentive to keep this going.
Comment by Guest, posted on Nov 27, 2007
no vista driver for lexmark z25
Comment by rostik, posted on Nov 26, 2007
I have same problem.
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
