Question about Pentax Optio S Digital Camera
When I press the menu button I get a yellow padlock symbol flashing on LCD. It is the same when I press the Mode button. Any ideas? Thanks
  • 2,200 Answers
Hi
The SD Memory Card/MultiMediaCard is equipped with a write-protect switch. Setting the switch to [LOCK] protects the existing data by prohibiting recording of new data, deletion of existing data or formatting of the card.
Check your SD card to see if the lock switch has not be activated as this can cause you to be locked out of the menu on the camera.
Hope this helps. Please remember to rate my answer. Thanks.
Posted on Jul 25, 2009
My DELL LCD MONITOR E178FP is locked, when i press menu button, on screen it displays lock symbol
Zaheer khan,
To unlock the monitor controls and get rid of the lock you can press and hold the menu button in for 20 seconds. You can also try the information listed in the link below.
http://www.paulstravelpictures.com/Dell-LCD-Monitor-Flashing-Padlock-Icon/index.htm
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 28, 2015 | Dell E178FP 17 inch LCD Monitor
LCD Stuck
Did you unlock the control keys? If you see an icon of a padlock on the screen you have locked out the buttons and need to unlock it. Look at the buttons and you will see the buttons have lines drawn from one to another. That means when those two buttons are pressed together, they perform a special function. To unlock the buttons you have to press two of the buttons that have the lock symbol drawn to them.
Sep 25, 2008 | Nikon Speedlight SB-800 TTL Flash
Power LED Flashing Yellow on Qosmio laptop F15
This flashing LED means only one thing, and it is quite harmless:
Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
Look for a symbol on keyboard for "sleeping" (like a half moon with zzzz) and press that key WITH whatever color coded key matches the symbol color (usually "FN" key). If there is no suchkey, press the space bar and hold it down a few seconds.
Then wait. Can take 60 seconds to "wake up" on slower processors.
If this does not work, press AND hold the POWER button for 10 seconds. Then wait 60 seconds and press power key again, briefly, to start laptop normally.
Pressing and holding the power button 6-10 seconds forces a complete system shutdown.
If this happens often, something may be wrong with APM or ACPI settings/driver. You can go to start menu/settings/control panels/power management and adjust settings (or disable sleep/suspend and hibernation if all else fails to resolve situation)
good luck.
May 29, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba power led flashing yellow
This flashing LED usually means only two things, both are quite harmless:
1. Some laptops will flash the power LED when battery is charging. If this is the case, it should stop when battery is fully charged. This can be presumed if the laptop starts normally while LED flashes. If not, suspect step 2 below:
2. Your laptop is either "asleep" (suspended) or in "hibernation" mode.It does this if left for a long time with no activity/input from you. You must simply "wake the laptop up" now:
good luck.
Flashing padlock icon in the middle of the screen
When the icon is in the unlock position, hold down the Menu key (the far left button in the lower righht hand corner) on your monitor. This should bring up the menu. From there, you can reset the factory settings.
Mar 16, 2008 | Dell E172FPt 17" TFT LCD Flat Panel...
Unable to print message on the LCD
press MENU then the blue copy button (b/w) then fourtimes the arrow up button quite quickly after another.
Machine should switch to maintenance mode and all lights will flash.
Mar 11, 2008 | Brother MFC-5840CN All-In-One InkJet...
How to unlock a Pentax Optio W10
press menu and the trash / delete buttons at the same time. Hold for 3 seconds until it beeps. WALA unlocked:):)
Mar 07, 2008 | Cameras
Symbol of a lock
I had the same problem - try this. Switch to playback mode by hitting the play button. In playback mode try the menu button (It worked for me). In the settings scroll down to the reset option and reset all camera settings.
Hope this works for you
Dec 11, 2007 | Pentax Optio S5i Digital Camera
I had the same problem. You locked your flash by mistake if you have a lock symbol on your LCD. Press the ON/OFF & Sel buttons simultaneously & the lock symbol will disappear. Then reset your unit by pressing Mode & ON/OFF simultaneously for 3 second & you are good to go!
Nov 16, 2007 | Nikon Speedlight SB-800 TTL Flash
Pentax Optio S Digital Camera Logo
104 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
