SOURCE: wall mount hardware
The bolt size you need is: M8-1.25 X 20. 20 is the length that I used and it works well. You could also use 25 (which is a little longer) if you would like. It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
SOURCE: remove tv from wall mount
there is an anti theft device on the wall mounts you need the manual to adjust mount to take off
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=255670bad135aec3653b726b698def9d&q=Samsung+PDP4294
heres the link just follow instructions to get download i will also be posting it here on fixya too
this the manual
SOURCE: fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
SOURCE: 42LC7D-AB cant find bolts to fit for wall mount
http://www.scribd.com/doc/6399173/LGTV
here is the owner manual. look on page 16 and you will see one way to wall mount. Ragarding the size of the bolts needed, go to the hardware store and get one bolt of each size close to what u think u need and use the trial and error method. OR go to an electronics store and ask one of the techies. Be nice and they will help u for free.
SOURCE: what size bolts hold the wall mount bracket to the
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
TV Wall brackets: http://www.regencyproducts.co.uk/
http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
