Question about SkyGolf SkyCaddie Handheld GPS Unit
Cannot sync gps with computer, cannot find
Tried 2 different computers and another gps computer cable same results
    Brigadier General:
  • 4,090 Answers
Either the GPS is faulty or there is an incompatibilty with OS of PC Especially Vista
Posted on Jul 26, 2009
Garmin nuvi 1310 will not charge using pc. It will charge on car battery but batt charging symbol does not display.
A couple of things to try: 1) Use a different USB cable. The one you're trying to use my not be working properly. 2) Try the other USB ports. Most computers have more than one, and there may be an issue with the one you're using. Usually, two USB ports are supplied from the same connector inside the computer, so you might have to try all the USB ports. 3) Try charging the GPS on a different computer with both cables.
Most of the time, one of these solutions will solve the problem. Good luck! Please rate my reply, thanks.
May 15, 2011 | Garmin nuvi 1300 Car GPS Receiver
Mt nuvi 3750 can not be found by 3 computors, says no devise found ? what could my problem be ? 2 pc's with win 7 , one with win xp, all i want to do is update my garmin..
Try a different USB cable.
The likelihood that 3 computers all have a failed USB ports is pretty slim. Using the same USB cable to connect the 3750 to them however throws suspicion to a defective USB cable. If it still doesn't work with a different cable - then it could be the 3750. Before doing anything else, check it out with the new cable on several computers. If it still fails to connect, contact Garmin Support.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 09, 2011 | Garmin GPS 3700 series Garmin nuvi 3750...
Display only blinks, how to reset the unit?
hey there michael_wick,
you need to install version 1.68 first before the 2.14 unless you have that installed already.
why cant you update it via the USB cable to your computer...all magellan GPS require at least Windows OS XP service pack 2 to sync with the computer.
if your not seeing the crossover listed in your computer, can you see the usb connection wizard in the lower left of the task bar on your computer.
btw, is this a true crossover, or a 2200T thats been upgrated with the crossover firmware?
Bill
Standing Member of G.O.T.
PLEASE SUPPORT OUR TROOPS
Oct 12, 2010 | Magellan Crossover GPS
Computer (Mac or PC) won't sync computer does not recognize the unit is plugged in
  • Check the cable make sure it is properly connected and use other usb cable just to make sure if the cable is the problem or the unit.
  • After you use other usb cable and still the same call customer service of Magellan advised them that you already used different usb cable and still the same it is not working. They will check in their and if they checked its really not working they will check if still under warranty so that they will repair it or you can request for replacement.
Jun 14, 2010 | GPS
Upgraded to the SGX and now the Caddy Sync won't work.
Had the same problem when i first tried to sync on 2 different OS (XP and 7) as soon as I put skygolf.com into my antivirus software as a trusted site, it worked like a charm. Hope this helps someone as this is a great gps.
May 08, 2010 | SkyGolf SkyCaddie SGX GPS Receiver
Computer fails to "see" the 210 when attached by USB
I talked with Magellan Support today (12/26/08). Their solution was to borrow a friends Windows XP system. I did and it worked. They DO NOT have a solution for Vista and claim that since Vista came afterwards they are not accountable for making it work on that O/S.
Dec 07, 2008 | Magellan eXplorist 210 GPS Receiver
Speedstream 4200 and Linksys WRT54G router
there are several types of patch cables, but basically there are 2 general types: one for servers (they keep the websites) and for computers.
the servers need to communicate with each other in order to be in sync. so some cables are switched in one end.
The computers just want to receive and send data; it does not care about sync.
Aug 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Evesham Nav-cam 7000 gps usb cable
same as me, I have done a lot of searching with no result. the connector in the unit is a non standard usb, evesham can't tell me the type.
Mar 19, 2008 | Evesham Nav-Cam 7700 GPS Receiver
SkyGolf SkyCaddie Handheld GPS Unit Logo
369 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
