Question about Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop
What does the red switch on the back of my dell dimendion e510 do
There's numbers on this switch that says 150 and 230. im wondering what they do when u switch it to 230.
  • Harvey Morrow
    Harvey Morrow May 11, 2010
    This is to allow the computer to be used in Europe and elsewhere where the wall voltage is 230. If you are in the USA, do NOT move the switch. You won't hurt anything but it will not work in that position. If you live where they have 230, using the 115 will FRY the power supply.
  • 61 Answers
Don't! That's for foreign voltages. It should say 115 and 230. The 115 is for 120V systems while the 230 is for 240V systems. The actual voltage you get is usually a little less than ideal, so they design power supplies to accept a lower voltage.
Posted on Jul 25, 2009
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
Apr 13, 2012 | Dell Dimension E510 PC Desktop
I have a Dell dimendion DM 061 running XP service pack3, every time I try to connect my Ipad2 IO5 the pc crashes and I get the blue screen
The blue screen crash is a hardware/software problem that cause. Please edit your system specs section in your control panel here on the boards with all the info about your setup motherboard, (with model number) CPU, video card, PSU, etc
Hope this helps, thanks for using fixya.com
Oct 24, 2011 | Computers & Internet
PC won't startup
either your ram or cmos cell is damaged,
Firstly remove one ram and power on it
Secondly change the cmos cell which ois on the motherboard
May 20, 2010 | Dell Dimension™ E510 PC Desktop
Dell Dimension E510 - Keyboard compatibility
Hi, to find out if the “Keyboard is compatible with your system?” You can do the following: Shutdown the Computer, connect the Keyboard to your computer. Turn on the computer. If, the “Keyboard have a Power Button?”(Turn on) the keyboard. Go to, Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to Update Drivers! Click OK. Restart the computer. Check keyboards’ functionality. Thanks paul7of9
Jan 14, 2010 | Dell Dimension™ E510 PC Desktop
How do you find the model number of your Dell Dimension E510?
Typically it is on the label on the backside of your computer.
it should give you model #...serial # and other information
Nov 27, 2009 | Dell Dimension E510 PC Desktop
I want to install a memory upgrade into a dell pc dimension E510
Go to Crucial.com put in your model number then they will list the memory you need and the highest amount of memory your pc takes. And Shipping is usually Free.
Sep 18, 2009 | Dell Dimension E510 PC Desktop
Want power pins on the motherboard of a dell dimension E510
Hi, i think u need to talk to dell support chat, they will give you more info, or else try them in parallel, i mean like terminate with a screw driver or u can download the service manual for this like Dimension E510.
Hope that helps
Cheers
Apr 27, 2009 | Dell Dimension E510 PC Desktop
CD WANT BURN ALL THE WAY
if the problem persists with different types of discs and you've already tried multiple burning programs...nero, roxio, nti..then your problem is with the dvd drive specifically. you can get a new one fairly cheap for less than 50 dollars.
Apr 26, 2009 | Dell Dimension™ E510 PC Desktop
Dell Dimension E510 Powers Up, Then Crashes
It's the processor or power supply. I cant be sure of which without checking it.
Check the fan over the processor heat sink to make sure its working cause it could mean that the processor is overheating If the fan turns and then it cuts off this could meant that the processor is dead. or the bios is corrupted. Try flashing the bios, there is a battery on the main boad, remove it. unplug the system first... when the battery is out press and hold the power button for 10 seconds then release. put the battery back in and try to turn it on..
If that fails then try a new power supply or one from another system to to check if the power supply is fine. YOu can aslo bridge the green and any black wire from the power supply's mainboard connector to see if the power supply runs. If all this fails then you may need to replace your processor,, I';d also recommend changing the power supply as well.
Nov 14, 2008 | Dell Computers & Internet
Dell Dimension E510 Dual Core 2.8 Ghz (847403171179) PC Desktop Logo
684 people viewed this question
Alun Cox
