Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer not working, think the timer is bad.
If the timer knob is manually held (jiggled) on the 20 minuted "timed drying" setting the dryer runs and will heat up, it won;t work at any other "timed" setting. The knob has to be held because when you let it go the buzzer goes off and the dryer stops.
The fluff air will also work if manually held but once let go, the buzzer goes off and it cuts off.
The timer knob will not work at all in the "electronic miser" setting.
It still clicks and advances, just won;t operate dryer.
Just want to make sure this is a timer problem and not something else.
Thanks!
  • Whirlpool Master
  • 1,606 Answers
Sounds like a timer problem .
Posted on Aug 01, 2009
I have a gas dryer. It heats up just fine, but it won't shut off. if put on time dry it won't count down the time and on any other cycle it will just keep running and drying
Oh I can't think of the name of it right now but the whole knob assembly inside needs to be replaced. It's like a timer its integrated into the knob.
Jan 05, 2015 | Dryers
Wed5100vq1
90% sure it's the timer
Jan 30, 2014 | Whirlpool WED5100VQ Electric Dryer
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
May 02, 2013 | Dryers
Timer not working....turn knob to 30 minutes and it stays on forever! Knob never moves from 30 mins....please help!
Most likely the timer motor or the main thermostat is bad (some dryers hold the timer off until the thermostat says the dryer is warmed up). I assume you have adequate heat since you do not mention any problem with the clothes not drying in the usual time.
Usually there is a wiring diagram hidden inside the control panel or posted inside the back panel. If you can read it, you can figure out whether a thermostat controls the timer motor. (I've never had to work on a Whirlpool dryer control problem, so I can't tell you.)
Mar 08, 2011 | Whirlpool LER5636P Electric Dryer
Kenmore dryer dial knob stripped?
You have a 1995 Dryer built by Whirlpool, which is the best manufacturer of Dryers. 30 to 40 yr lifespans with rebuilds every 8 to 20 years depending on usage. You are correct, you have a bad timer assembly with bad points, and you need to replace the timer. Before you do this you need to check your belt to see if you need to rebuild the dryer also. I would be surprised if this does not need to be rebuilt at this age, you may have already replaced the belt, drum support rollers and idler pulley. To check your drive belt, you need to lift the lint filter cover and remove the two screws in front of the filter. Grab the top of the dryer and pull it towards you on one side as you lift the front of the top. There are two clips on each side that are holding the front of the top down, you are pulling the top toward you and up to clear these clips. The whole lid will then tip back and you need to lean this against the wall while you check the belt. Always do this with the power off at the circuit breaker. Grab the belt and flip it upside down in about a 10 inch section and inspect it to see if there are any cracks in the belt. If there are, you need to rebuild the Dryer. They have kits for this with directions but I recommend that you ask for the red drum support rollers instead of the white ones they have in the kit. Good Luck Appliance Specialists
Dec 14, 2009 | Washing Machines
Dryer does not stop - timer knob does not turn so dryer continues
do you have it on more or less?,if so the timer will not move unless there is heat, do you have heat?are the clothes drying ?if you have it on time dry the timer is bad try moving it past the spot were it's sticking and see if it counts down
Nov 03, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Gas Dryer keeps running on auto dry setting
When you moved the sensor wire on the moisture sensor may have fallen off.
Remove the front panel and locate the wire and the connection. It will be on the right side near the lint filter vent. If it is still connected your timer has gone bad.
Mar 26, 2009 | Whirlpool Dryers
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
556 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
