Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Desktop does not fit widescreen - there are black strips on sides
We purchased a new monitor, the desktop appears with about 2" of black on the sides - i tried several ways to see if I could find a place to adjust the desktop i.e. right click "properties" etc. - no luck
    Scholar:
  • 151 Answers
Going though your computer settings will not adjust the black parts on the screen,
What you need to do is adjust the settings on the screen, if there are no buttons on the screen you may need to read your manual.
Regards
Posted on Jul 25, 2009
Ghosting?
Verify:
1- the backligth is on (is led light)
2- the controller video board on this monitor
from your photo seems to be a problem with the backlight, but this is a LED -> a think you will be force to change the display.
good luck!
Apr 01, 2014 | Dell Studio S2340L 23" IPS Widescreen LED...
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
I have Toshiba SATELLITE P105-S6197 Laptop and suddenly a horizontal while/grey lines appeared as a strip and after windows login it appears as a black strip at right side
Sounds like a bad screen. The easiest way to verify that would be to attach this to an external monitor (at work, a friend's ... if you ain't got one) - if the external monitor apprears good then you've pretty much iso'd the problem to your laptop's screen. This model uses a 17" widescreen. Best place to buy 'em would be on eBay, and they'll usually run around $90 to $100 if you need one right away - half that amount if you've got time and patience :-)
Sep 06, 2011 | Toshiba Satellite P105-S6197 Laptop...
I have an old tube tv screen, 19 inch. Fable 3 just does not seem to want to fit properly. I am missing about an inch on all sides. I am pretty sure my xbox settings are right.
Most 360 games are made for High Definition Widescreen now.
Have you got an aspect ratio button on your remote? Try switching it to 16:9, and changing your Xbox settings to "Widescreen". You may get the two black strips top and bottom, but the game should look fine. I hope this works for you, as I know how annoying that can be!
Jan 26, 2011 | Microsoft Fable 2 for Xbox 360
Why is image on screen is to wide
A wide screen display requires setting the appearance
procedures
1. right click on a space on the desktop without icons
2. select from a list prompt the settings with click should provide link with which to select the appearance setting
3. choose from the display icon prompt after clicking a pixel quality
4. a larger figure chosen from the list should decompress the screen pixels creating clear pictures though adjusted screen to fit the area
Dec 06, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
Re ACER V203H 20" monitor - appearance. Why is the image size only 16" with black margins approx 2" on left and righthand sides? I bought this monitor brandnew - thought it was widescreen. If I change...
It is definetly a widescreen the issue is either with your display card or your resolution setting you need to check both. If you would have told me wether your display is through mother board or scsi card the model of mother board or the display card then i could fix the issue easilly.
Mar 06, 2010 | Acer V203HA Monitor
No manual, don't want to screw-up new monitor
Start, Control Panel, Display, Settings, select for resolution 1600 x 900 , Apply , OK
Dec 04, 2009 | Televison & Video
I have a new flat panel 21" monitor which I love. However, photos which I took of taller objects and some Windows games appear too wide and not tall enough. The same thing can happen on the new TV's when...
It sounds like you have the resolution set wrong. Typical monitors are setup with a 4:3 aspect ratio. With the widescreen monitors, you have to get a resolution that will support the 16:9 I purchased a dell monitor a while back that was the same way, and I just went in and made sure I had it set for the 16:9 aspect ratio.
Right click on the desktop, go to Personalize(Vista) or Options, and then system tab, and slide the bar along the resolution ruler to the correct size. Play with them a little too, to make sure it fits you best. Some of the higher resolutions will show more screen space, but will have smaller text.
Mar 15, 2009 | HP w2558hc 25.5" Widescreen LCD Monitor
No display, clipping sound appear
The clipping sound is the internal safety switch that keep shutting down the monitor.
It means there is an internal problem on the main board (overvoltage, bad component , short).
Try unplugging power cord and leaving it unplugged two or three hours, this will reset ICs by draining power completely from circuits, it is called hard reset, it rarely works.
CRT monitors waste up to 15 times more energy than TFT screen, if your CRT starts giving troubles, then it is a good time for upgrading it to a new TFT.
17'' start at $120
17'' Dell 1703FPt DVI LCD Monitor w/USB Hub (Black/Silver) -B
171ABB 17" Widescreen LCD Monitor - 1440x900 (WXGA+),
Envision H716A4 17 in. LCD Monitor
19'':
19'' Princeton VL1919 DVI LCD Monitor (Black)
19'' panoramic
V7 Series D19W12 19" Widescreen LCD Monitor
Sep 10, 2008 | ViewSonic E70f 17" CRT Monitor
How do I get the widescreen monitor to show unstretched images?
i had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
196 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
Gregg Errera
Gregg Errera
Level 1 Expert
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
