Question about Toshiba Satellite L305D-S5895 Notebook
Why I cant hear anything from the headfones? - Toshiba Satellite L305D-S5895 Notebook
  • 71 Answers
Check your system sound setting and make sure it is not set to digital out. Assuming head phones are good, make sure WDM sound driver and device manufacturer drivers are not conflicting.
Posted on Jul 25, 2009
Headfones dont work
Your headphones are dead! The wires inside the plastic tubing are fried! Sorry man but you're going to have to buy a new pair of headphones!
May 04, 2014 | Samsung s150G Black Cell Phone - TracFone...
I have installed t sound driver.. but i can hear a constant sound whenever i use it and if i talk over t headfones even the other side who is hearing me can hear the noise also... how can i solve this??
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 14, 2012 | Intel D915GAV Motherboard
When somebody rings me I can hear them but they can hear me on my blackberry bold
I think your Blackberry cell phone`s mouth piece or Mic is not working,it is a hardware problem go to the nearest mobile shop to figure it out.
THANKS ! ! !
Sep 11, 2011 | RIM BlackBerry Bold 9000 Smartphone
How to play radio on 6030 nokia without headphone
there is no option available for this function in nok 6030,but with a help of damaged headfone you can do this, just cut the wire of your old damaged nokia's headfone form just the pin and then insert only the front pin in the jek of headfone in nok6030 and put the loudspeaker on.... and you get your solution with this little compramise.....
thanks, Rgrds: rajiv kumar 09811461147
Mar 28, 2009 | Nokia 6030 Cellular Phone
To listen radio without headfone
Press the speakerphone button on the side.
Jan 12, 2009 | Motorola Mobility W230 Phone US with...
Sound
go to sound setting and make headfone primary device ..or disable speakers in contol pannel
Jan 11, 2009 | Compaq Presario Notebook
I am not hearing any sound at all though i have increased every volume buttom
You check your system information if sound driver was installed, type dxdiag in your run command. Wait till a tool bar about your system info will appear then check your sound driver if installed. If it was not installed. you have to install a sound driver. Look at your sound card installed and download from internet any necessary sound card driver compatible to your sound card hardware and mother board. Just try this,. I have solved many computers by following this procedure.
Oct 19, 2008 | Compaq Creative Sound Blaster PCI 128...
Not a good sound
could simply just be the earphones... sometimes it just means ur heaphones are stuffed.
if its not the headphones either the player is stuffed or the audio format is something the X20 can't read
if its the player i'll be frank, you have no hope, there are no specialised stores that can fix it besides iriver international (they'll only take it if its still in warranty). you cant fix it yourself unless you have thorough knowledge of the circuit.
If its the sound format try changing it to mp3 or wma...
hope this helps!
Jul 25, 2008 | iRiver X20 MP3 Player
Headphone not working on the headphone.
Try the headfones through a sterio or something just to see if the headfone itself is not faulty if it is take it back to the shop and get a replacement. Else the socket for the plugin is faulty.
Sep 22, 2007 | Everex StepNote VA4103M Notebook
Toshiba Satellite L305D-S5895 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
