Question about Dometic RM2652 Refrigerator
Freezer works well, fridge not cooling.... what's the problem?
I have the same problem as the last guy posted. The manual provided does not speak to this problem. How do I fix it?
  • Mike Smith
    Mike Smith May 11, 2010
    What brand and model number ? Is there frost on the inside back wall of the freezer ( about 1 foot up ) ? Is the fan working in the freezer ? Are your coils clean from dust ?
    Champion:
  • 363 Answers
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Posted on Jul 30, 2009
We just bought a GE gbe21dgkarww we are having trouble wth the crisper, they are freezing my fruit and vegetables. Temp. Cool on freezer on coldest
Fridge temps are actually cooled by the freezer,try turning freezer temp down somewhat-and I highly recommend buying a fridge thermometer,generally speaking I try to keep my fridge at about 34-35 degrees,you can go SLIGHTLY higher,is fridge section directly over freezer??
May 09, 2017 | GE Refrigerators
Refrigerator not cooling, at last check 55 degrees, freezer working fine, can not find owners manual help
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
j
Sep 27, 2010 | Amana ABB2227DE Bottom Freezer...
Fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Jun 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Tempratue problem
air from the freezer fan, means the sensor- temperature control circuit is working right, it is trying to cool
there has likely been a leak from the system and there is not enough coolant left for the compressor to compress anything.
a GOOD repair guy
will have a pressure pump/gauge and test for leaks through the fill nozzle, repair them and regas the fridge (provided it is a non-CFC r12 fridge) without removing it from the home,
a not-so-good repair guy
will not
Sep 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Freezer stopped working
Solomonau, it's hard to tell without being there exactly what is going on. I do know however,that in April of 2005 Samsung came out with a bullitin regarding the cap tube. It states that it has been inserted into the dryer incorrectly and can cause no cool situations. This is part of the sealed system which should be covered for 5 years. What you are describing sounds like a partial restriction, which could be taking place in that dryer and cap tube. If you were to post your model number, I would be able to tell if yours was included in this bullitin. You can then contact Samsung and inquire about this service bullitin, Catriver..post back.
Sep 19, 2006 | Samsung RS2534 Side by Side Refrigerator
Dometic RM2652 Refrigerator Logo
329 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
