225 mr will not play burn MP3's
I have the manual and copied it verbatim for you. Please let me know if you need me to scan the manual for you.
Acceptable medium formats:
The following formats are available for the media used in this unit. The maximum number of characters used for file name including the delimiter (".") and three-character extension are indicated in parentheses.
? ISO 9660 Level 1 (12 characters)
? ISO 9660 Level 2 (31 characters)
? Joliet (64 character; Up to 32 characters are displayed)
? Romeo (128 character; Up to 64 characters are displayed)
? Long file name (200 characters; Up to 64 characters are displayed)
? Maximum number of characters for folder name: 64 (Joliet; Up to 32 characters are displayed)
For a list of available characters, see the instruction manual of the writing software and the section Entering file and folder names below.
The media reproducible on this unit has the following limitations:
? Maximum number of directory levels: 8
? Maximum number of files per folder: 255
? Maximum number of folders: 50
MP3/WMA written in the formats other than the above may not be successfully played and their file names or folder names are not properly displayed.
Settings for your MP3/WMA encoder and CD writer
Do the following setting when compressing audio data in MP3/WMA data with the MP3/WMA encoder.
? Transfer bit rate MP3: 8 ?320 kbps
WMA: 48 ?192 kbps
? Sampling frequency
MP3: 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz
WMA: 32, 44.1, 48 kHz
When you use your CD writer to record MP3/WMA up to the maximum disc capacity, disable additional writing. For recording on an empty disc up to the maximum capacity at once, check Disc at Once.
Play mode may not be possible when portions of the functions of Windows Media Player 9 or higher are used.
Entering ID3 tag:
The Displayable ID3 tag is ID3
version 1.x. For the character code, refer to the List of Codes.
Entering file and folder names:
The code list characters are the only file names and folder names that can be entered and displayed. If you use any other character for
entry, the file and folder names are not displayed correctly. They may neither be displayed correctly depending on the CD writer used. The unit recognizes and plays only those MP3/WMA which have the MP3/WMA extension (.MP3/.WMA).
A file with a name entered with characters not on the code list may not play correctly.
Writing files into a medium:
When a medium containing MP3/WMA data is loaded, the unit checks all the data on the medium. If the medium contains a lot of folders or non-MP3/WMA files, therefore, it takes a long time until the unit starts
playing MP3/WMA. In addition, it may take time for the unit to move to the next MP3/WMA
file or a File Search or Folder Search may not be performed smoothly. Loading such a medium may produce loud noise to damage the speakers.
? Do no attempt to play a medium containing a non-MP3/WMA file with the MP3/WMA extension.
The unit mistakes non-MP3/WMA files for MP3/WMA data as long as they have the MP3/WMA extension.
? Do not attempt to play a medium containing non MP3/WMA.
