Sony BDP-S300 Blu-Ray Player
Problem for Sony BDP-S300 Blu-Ray Player
Phillips RC144-5302 remote control code for Sony BDP-S300 Blu-Ray
By dingzxy on Jul 25, 2009
Need the Phillips RC144-5302 remote control code to control Sony BDP-S300 Blu-Ray DVD
Comments:
Jul 25, 2009
- I could not follow your instruction since my remote control Phillips RC144-5302 ( for Verizon Fios)does not have the magic key.
Ding
Jul 25, 2009
- Need the code for Phillips RC144-5302 remote control ( for Verizon Fios) to control Sony BDP-S300 Blu-Ray DVD
Thanks,
Ding
Comments:
Jul 25, 2009 - I am not able to follow the instruction since my remote control Phillips RC144-5302 ( for Verizon Fios)does not have the magic key.
Ding
Jul 25, 2009
- Yes, I did, These TV remote control codes do not work with my Sony BDP-S300 Blu ray player.Thanks
Jul 26, 2009
- Need the code for Phillips RC144-5302 remote control ( for Verizon Fios) to control Sony BDP-S300 Blu-Ray DVD.
I have tried all the codes the RC144-5302 manual prvides. None of them works
Ding
Jul 26, 2009
- It is not working. After tring the 300-code scaning with your suggestion. I will call the Verizon Fio tech support.
Thanks
Jul 29, 2009
- I have tried all the ways in this verizon Fios remote manual . none of them works for Sony blu ray.
Ding
Jul 31, 2009
- I already tried the method you suggested in the Verizon remote control manual before and had no luck.
Now I have bought an Universal remote control WR7, But I still could not use it to have the setup menu for Sony BDP S300 Blu ray. Could you help me on that.
Thanks.
Jul 31, 2009
- The WR7 remote can only control the play function for Sony BDP s300 blu ray . I need the WR7 code to control the sony blu ray setup menu function.
Aug 05, 2009
- Since I don't have the original remote control of SONY BPD S300.The WR7 remote can only control its transportation functions . I do need a WR7 code to control the SETUP for configration of the Sony BDP-S300 ,
Aug 06, 2009
- All the RC144-5302 remote control codes for Sony BDP s300 had been tried . No luck.
Aug 07, 2009
- I did try that codes already. Not working at all.
Thanks.
Aug 08, 2009
- I better give up now, you are right. Thanks
Aug 08, 2009
- No luck by trying your 3 codes. I have bought a WR7 remote control, which can only control the transportation functions . I need the code to control setup of the Sony BDP-S300.
Thanks
Solution #1
posted on Jul 25, 2009
Somewhat Helpful)
rylee_smith
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 88%, 1109 votes
Hi
Please follow this procedure for a oneforall remote:
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing
3. Put the player back into standby with the Sony remote
4. Next time you turn on the player it will be region free for DVD playback.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Comments:
Jul 25, 2009
- Hi
You can try some of these codes. As these are the codes for Sony TV for Verizon Fios
0027, 0861, 1127, 3002, 3050, 3054, 3069, 3077, 3103, 3116,
3123, 3126, 3143, 3150, 3151, 3155, 3178, 3198
Thanks
Rylee
Jul 25, 2009
- Did you try these codes:0027, 0861, 1127, 3002, 3050, 3054, 3069, 3077, 3103, 3116,
Thanks
Rylee
Jul 25, 2009
- It means that Phillips RC144-5302 remote control does not support your DVD and thats the reason its not working even with these codes.
Please revert for further assistance.
Thanks
Rylee
Solution #2
posted on Aug 08, 2009
Not Rated)
Ekse
Rating: 88%, 4974 votes
Try the following codes
Sony
0560, 0891, 1060, 1458, 1560,
3312, 3316, 3318, 3319, 3321,
3335, 3338, 3342, 3361, 3362,
3366, 3374, 3377, 3393, 3427,
3435, 3454, 3459, 3461, 3471,
3498, 3499, 3505, 3507, 3530
If none of these codes worked follow these instructions available at http://ekse.pp.fi/Fixya/Remote.jpg (there are total 9999 possible codes)
Solution #3
Not Rated)
njvinod
Rank: Wiz
Rating: 85%, 437 votes
I Think 1023,1024 and 0816 should enable it to control your player
Solution #4
posted on Aug 06, 2009
Not Rated)
cbr2009
Rank: Wiz
Rating: 84%, 74 votes
Below is the user's manual for your remote control in PDF form. It has the instructions along with the codes. For your convenience I have included the codes from that manual for your Sony BDP-S300 Blu-Ray DVD. The manual recommends starting in the beginning because the first codes are more common. http://onlinehelp.verizon.net/consumer/bin/pdf/Philips%20RC1445302%20User%20Guide.pdf Sony BDP-S300 Blu-Ray DVD Codes
0560, 0891, 1060, 1458, 1560, 3312, 3316, 3318, 3319, 3321, 3335, 3338, 3342, 3361, 3362, 3366, 3374, 3377, 3393, 3427, 3435, 3454, 3459, 3461, 3471, 3498, 3499, 3505, 3507, 3530
Solution #5
posted on Aug 05, 2009
Not Rated)
virtualhost
Rank: Guru  Sony Expert
Rating: 86%, 680 votes
Hello Ding,
Have you tried checking this pdf file?
OR try the FF. codes:
Solution #6
posted on Jul 26, 2009
Not Rated)
rockitman187
Rating: 90%, 1897 votes
Searching for a Device Code
  1. Turn on the device you want to program into your remote, for example if you are programming your remote to control your TV, then turn on the TV.
  2. Press and hold the device button for the device you turned on in step 1 (DVD, AUX, TV, STB) and press OK. Release both buttons.
    The mode buttons blink twice.
  3. Press 922.
  4. Point the remote control toward the device you are setting up and press the upper part of the Play button.
  5. Press the Fast Forward button. If the device you are setting up does not turn off, keep pressing the Fast Forward button until the device powers off. (You can use the Rewind button to go back, if necessary.)
  6. When the device powers off then you've found the correct code for that device. Press OK to assign the code in your remote control.
    Note:
    There are over 200 possible combinations for TV and DVD codes. The most common codes are tried first but you may still need to press the Fast Forward or Rewind buttons over 200 times to find the correct code for your device.
    If you reach the end of the list of codes, the entire remote flashes twice and returns to normal operation. You can exit programming at any time by pressing the Exit button
Solution #7
posted on Aug 07, 2009
Somewhat Helpful)
sp4m771
Rank: Wiz
Rating: 85%, 58 votes
Try the BDP-S300 codes at this link: http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=prontong&db=devices&br=sony&dv=blurayplayer
If that doesn't work, read the manual here http://onlinehelp.verizon.net/consumer/bin/pdf/PhilipsRC144RemoteControlUserGuide.pdf
Comments:
Aug 07, 2009
- I think you just have to give up.. Either that, or talk to the Verizon FiOS or Sony techs.
Solution #8
posted on Jul 29, 2009
Somewhat Helpful)
anandg27
Rank: Guru
Rating: 86%, 410 votes
If none of the codes work there is a way to try EVERY SINGLE DVD CODE STORED IN THE REMOTE! To try that, use the following procedure.
1. Turn on your Sony DVD Player.
2. Press and hold the DVD key on the Verizon Remote.
3. On the Verizon Remote while holding down the DVD key, press OK.
4. Release both keys at exactly the same time. The Device Keys will blink twice.
5. Press 9 - 2 - 2.
6. Point the remote at the Harmon Kardon DVD Player.
7. Press >/II (play/pause) button
8. Press >> (ffwd button) Every time you press >> (ffwd button) the remote sends out a new power-off command to the DVD Player. Keep pressing >> (ffwd button) until the DVD Player turns off. (You can press the << button to go back.)
9. When the DVD Player turns off, you have found the right code. Press OK to store this code.
Note: There may be over 100 codes. Get your finger ready. The most common codes are tried first, but you may still need to press the >> (ffwd button) over 100 times to find the right code! If you reach the end of the list of codes the entire remote will flash twice and return to normal operation. You can exit programming at any time by pressing the Exit.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Comments:
Jul 31, 2009
- Hi, Download the manual for WR7 from the link below :
http://universalremote.com/resources/pdfs/wr7_manual
Check the required codes from the manual.
Jul 31, 2009
- Hi,
Check the link below for more info:
http://www.wishpot.com/public/products/?ps=1&pspid=B001KC08A4&view=reviews&pgpr=2
Aug 05, 2009
- Has the issue reloved? If not, then let me know so that we can work for a solution.
Solution #9
Somewhat Helpful)
greenspan
Rank: Wiz  Televisions & Videos  Expert
Rating: 82%, 689 votes
Here is the manual which describes the auto-programming and has codes for Sony players
Comments:
Aug 07, 2009
- Otherwise ask at http://manualfox.com/remote.htm
They are specialized on finding any code.
Popular Solutions for Sony BDP-S300 Blu-Ray Player
Questions and Unsolved Problems for Sony BDP-S300 Blu-Ray Player
Do you recommend Sony BDP-S300 Blu-Ray Player?
Answer
Answer
Can you program a Samsung ln-46B650 remote to operate other devices like my sony blu ray player?
Answer
I need a battery cover for a sony blu-ray remote rmt-b101a
Answer
I just bought a new blue ray movie and placed it in my Sony blue ray player. After 20 minutes it was... (More)
Describe your DVD Players problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in Burnsville, MN
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
