Computers & Internet Logo
d
doris haag Posted on May 25, 2017
Number on baack of card does not much your records
1helpful
Hello I have a digital camera general electric E840s with a memory card 4G but i have a problem when i use to record a video clip the period of the record stop in 1.75 min. my memory card work very good
What class is the card? A class 4 or better will write faster allowing more video time. Look at the card closely and inside a letter "c" will be a number. If your video ends in 1.75 min. the number is probably a 2.
9helpful
Can not set time of recording
Hi and welcome to Fixya,
When you cannot get into put the time for recording on step number 4 all you have to do is to go back to step number 1. Double click on Pinnacle Instant DVD Recorder and choose go direct to the advance mode and click next.
On Step number 1 click on the pull down arrow and choose for dazzle DVC 100. Go back to step number 4 and now put the total and valid time recording.
If there is no Dazzle device on step number 1 go ahead and disconnect your dazzle and connect to another usb port or much better if you connect that at the back of the computer.Try it again.
1helpful
How do you get your min.in a Dazzle dvd recorder...............
Are you referring to put the time record or the total minutes for your recording? on step number one make sure that you choose your dazzle dvc device after that go ahead and go to step number 4 and put the total mins of your video.
1helpful
2answers
Camera flashes two times, but will not record a picture
this sounds like a problem with the sd card either being corrupt and needing formating or being to large. if made in 07 or older it takes 512 mb sd card max if in 08 or newer it will take up to a one gig sd card.
MY RAZR IS ACTING CRAZY...THE VOLUME SCROLLS UP AND DOWN..WHEN I PUSH A TRY TO DIAL A NUMBER IT DOESNT DO ANTHING...AFTER I PUT IN IN THE FRIDGE IT WORKED FOR ABOUT ONE MINUTE AND THEN THE SAME THING...
It sounds like you have a short in your phone. Make sure that the battery is out and that everything is dried out before you re-install battery and power up.
If you really think the phone needs new software then go to this website and enteryour info. The update is available.
http://www.motorola.com/consumers/v/index.jsp?vgnextoid=69fd5fc943dc0210VgnVCM1000008806b00aRCRD
1helpful
2answers
Can the sim card of a razor cell hold voice recordings?
The sim card is not involved with the voicemail. THe voicemail has it's own number that is dialed from the phone.
Unable to install pinnacle dvd recorder for recordeing anlog vide
Regarding to your Q.1.
Please check you video card if the drive is up to date. Please tell the what type of video card do you have in your computer?
To check go to device manager then click on the display adapter and you will see the exact name of your video card.
Regarding to your Q.2.
Make sure that in the step number 1 select video source the dazzle must be selected not pinnacle file capture.
Last, Q.3 you must accomplish first the given procedures in Q.1 and Q.2 so that this will fix the Q.3
1helpful
I am using an sd card when i hit the record button it says cannot record video on the model number DZ-GX5020
Sorry, but as far as I know, Hitachi camcorders cannot record video directly onto an SD card. You have to set the camcorder to DVD. It can only record video and pictures on a DVD, and only pictures on an SD card.
2answers
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Grand Canyon Tech
Grand Canyon Tech
