Have checked and cleaned drain filters, but have no idea how to check inlet valve filter or switch. the owner's manual doesnt have anything about it, and no diagram showing the inlet valve.
Inlet valve is underneath ..behind the "kick plate" ,,,you need to remove the kick plate to access it ...just look for the water line it conects to the valve ....it would be rare that this is cloged ...it may need replace ment ....make sure the actual water is turned on from your main hot supply ....some times people turn them off and forget to turn them back on ,,,,it's located under your sink
If your Kenmore washing machine is having trouble filling and then drains without spinning during the rinse cycle, there could be a few possible causes.
Water supply issue: The first thing to check is the water supply. Make sure the water supply valves are fully open and there are no kinks or blockages in the hoses. Also, check the water pressure and make sure it meets the manufacturer's requirements.
Faulty water inlet valve: The water inlet valve is responsible for controlling the water flow into the washing machine. If the valve is faulty, it may not be allowing enough water to enter the machine, which can cause the filling to take a long time. It could also be stuck in the drain position, causing the machine to drain instead of filling. You may need to replace the water inlet valve.
Clogged filter screens: If the filter screens in the water inlet valve are clogged with debris or hard water deposits, it can restrict water flow and cause the machine to fill slowly or not at all. Try cleaning the filter screens to see if this improves the water flow.
Faulty pressure switch: The pressure switch monitors the water level in the washing machine and tells the control board when to start and stop the filling and draining cycles. If the pressure switch is faulty, it may not be sending the correct signals to the control board, which can cause issues with the filling and draining cycles.
If you have checked the water supply and filter screens and they appear to be working correctly, it may be necessary to replace the water inlet valve or pressure switch. If you are not comfortable performing these repairs yourself, it may be best to contact a qualified appliance repair technician to diagnose and fix the problem.
"Check the tap" means difficulty with inlet water. Before anything I suggest to clean the water inlet filters as described in the user manual.
otherwise could be: Tap closed or water pressure too low; drain pipe improperly positioned; water fill solenoid valve faulty; leaks from water circuit on pressure switch; pressure switch faulty; wiring faulty; main PCB faulty.
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Clean your INLET and OUTLET filters, remove the inlet valve and check flow, also check the drain pump for clogging or lint collection. Click this link: Lint filter
First of all you mustt drain the water that is trapped within the drum. So remove the drain pump/ valve and allow the water to flow out - make sure that you have an arrangement to collect water when the drain Hose is removed.
Now the drain pump/valve must be checked clean if there is dirt clogging. Also test the valve for proper functioning. Also check the inlet valve and filter which is on line with the water inlet which can be traced easily. Check the motor, drive , door switch and finally the control board. If after switching on there is no action , inlet filling or spining when water is full, the program controller must be faulty.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
Check your drain hose for kinks or clogs.
Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
Make sure that the water valves behind your washer are fully open.
Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Hi. The above machine stops mid cycle and drain/fill light is on, also
error code F3E, have cleaned both hot and cold water inlet filters, also
checked drain pump and drain line, all ok. Machine drains with no
issues and fills with hot water, runs for a while then shuts down.
Any ideas?
