Question about Kitchen Ranges
The microwave will not turn on. I have checked the fuse and this is working. I have also checked the main fuse box and this appears to be fine. Do you have any other suggestions as to what may be wrong and how to fix it?
  • 52 Answers
Might need a new plug or power cord ...check with tester and replace if bad
Posted on Jul 25, 2009
Won't turn on. Shows no power to it but outlet fine,
Check input power supply by tester if its conform its OK then check the oven control box .try to check any abnormalities there .
Jul 19, 2016 | Bosch 500 HMB5050 Microwave Oven
Microwave portion malfunction
Did you mean that the microwave oven won't turn on at all?Did you try replacing the fuse?
May 24, 2008 | GE Advantium SCA1001SS Convection /...
Kenmore microwave 911 41479791 no power?
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 24, 2012 | Microwave Ovens
LCD pad, numbers do not appear clearly but as a distorted image. example 1:10 may appear as blank.1E example .40 may appear as blank.1L microwave works fine just the read out panel is distorted,...
On most recent Sharp microwaves, the fuse only interrupts main power, so if the fuse is blown, it will be totally dead.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes then try it.
Then chances are you have a failed microwave display. Unless this is an over the range, touch screen, or convection type, it's probably not worth repair, but you can get more information on such repairs here.
Jan 15, 2011 | Sharp R-310CW 1100 Watts Microwave Oven
My microwave made a funny noice a couple of nights ago, but continued to work fine after that but now it's completely dead. Checked the breaker and it's fine. Any ideas?
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARRAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 05, 2011 | GE JE1640 Microwave Oven
GEJE2160 Stop Working
It probably blew the main power fuse in side the oven. This may have happen because of a failure in the microwave or a line voltage surge or what ever. Repalce the fuse and see if it work. be sure to unplug it before doing this, If this does not fix it then you have a failure in the oven some were.
good luck
May 16, 2008 | GE JVM1850 1000 Watts Microwave Oven
Microwave stopping working
check the fuse on the microwave. if its busted, something shorted out in the oven that tripps off your breaker. it could be your inverter.
Feb 19, 2008 | Microwave Ovens
Whirlpool GH7145XF
Check your main breaker fuse in your panel/subpanel.
Otherwise if the inline fuse is good and the main power is good, then look at the power supply for the microwave.
Mike
Nov 09, 2007 | Whirlpool GH7145XF Microwave Oven
Microwave
be very careful cos microwaves can kill - there is very high voltage present even when disconnected from mains. unplug from mains & leave for 1 hour. remove cabinet. there is a fuse which controls everything usually located near the transformer or where the mains cable enters. check fuse and replace. it needs to be the correct fuse for the appliance
Mar 27, 2007 | Whirlpool MH1150XMQ Microwave Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
