Question about HP Photosmart C5180 All-In-One InkJet Printer
Parts fell out of printer during a paper jam. My printer is a hp psc1315 all in one.I took the cover off but I can`t figure where they go. forestlady38
  • forestlady38 Jul 27, 2009
    problem fixed. I took off the cover of my printer and put them where they belong.forestlady38
    President:
  • HP Master
  • 1,996 Answers
I'm not sure which parts you're referring to, but here's a guide to normal paper jam procedures, and here's a link to an online manual....
Without more specific info, I'm not sure where to point you, though if you contact HP support they can access an exploded diagram of parts for your printer that may help you....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 25, 2009
My kyocera KM 1815 keeps saying "paper jam 00 open left cover and remove paper jam but there is no jam
Hi
Check all the paper movement from the tray, left or right cover, front cover, if so then remove jammed paper. Otherwise the paper sensor spring guide missing or fell off from its original position. Check carefully where the sensor locate. paper sensors detect all the paper movement in the machine during copying or printing, so locate the place in the machine which the paper usually jammed, see the screen of the machine, it will locate the place where the paper jammed mostly. Sensor not return to it original position that is why ( remove paper jam keeps blinking)
Aug 11, 2014 | Kyocera Mita Office Equipment & Supplies
HP C6280 printer paper stuck deep inside remove cover
I suggest You Go to Official HP Printer Page For You HP Printer Problem On Below HP forum URL Link: Paper Jam Message Displays on the All in One In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : HP Printer Support
Feb 27, 2014 | Office Equipment & Supplies
Having message jam inside rear door and can not find any paper jam
Not all of the paper jam was actually cause by paper. There are also instances that the media is the one that is jammed, causing to display a "paper jam" message.
If you can't find any jammed paper from the unit, you can try inspect the following cause..
1. Trays are loaded improperly or overfilled.
2. Tray 2 or tray 3 is removed during print job.
3. The top cover is opened during print job.
4. The media that is being used does not meet HP specifications.
5. The media that is being used is outside of the supported size range.
Also, try to tun HP toolbox.. on the Paper Jam options, click the Typical Jam Locations... to see the internal paper path and potential jammed locations.
I hope this solve your problem...thanks..
May 28, 2010 | HP LaserJet 2420 Printer
My HP psc1315 will not turn on. Some of the
To be able to understand the problem, you should give extra info about the lights.
Please find the information below about the status lights that provide information about error conditions of your printer. But first you need to install the driver for your operating system. The drivers are necessary to print documents and scan images. These drivers must be installed to use the print and scan features.
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HP PSC.
2 Turn your HP PSC off and on by disconnecting the power cord and reconnecting.
Problem 1: “ON” light is on, “check paper” light is blinking and “check print cartridge light” is off .
Explanation 1: The paper tray is empty, the HP psc has a paper jam, or the paper size setting and paper in paper tray are not the same.
Solution 1:
• Load paper, or remove thepaper jam.
• Change paper in paper tray to correct size.
• Change paper size on the computer software.
Then press On/ Resume to continue.
NOT : PLS SEE THE NEXT MESSAGE. CONTINUED AS THE COMMENTS BELOW:
Mar 31, 2010 | HP PSC 1315 All-In-One InkJet Printer
Hp LaserJet 4100 printer says its out of paper which is not the case, could someone assist me and figure what may be causes this problem? Thanks in Advance
Paper jams can occur in the following areas
1 Top cover and toner cartridge area
2 Optional envelope feeder
3 Input tray areas
4 Optional duplexer
5 Output areas (top and rear)
6 Fuser area
Solving repeated paper jams
* Check all the paper jam locations. A piece of paper might be stuck somewhere in the printer. Even a small torn piece of paper in the printer path can cause repeated jams.
* If using a duplexer, check all areas (including under the duplexer).
* Check that paper is correctly loaded in the trays, that all three adjustments have been made, and that the trays are not overfilled. Make sure paper is under the front and back tabs.
* Check that all trays and paper handling accessories are completely inserted into the printer. (If a tray is opened during a print job, this might cause a paper jam.)
* Check that all covers and doors are closed. (If a cover or door is opened during a print job, this might cause a paper jam.)
* Try printing to a different output bin.
* The sheets might be sticking together. Try bending the stack to separate each sheet. Do not fan the stack.
* If you are printing from tray 1, try reducing the size of the stack.
* If printing from the envelope feeder, make sure it is loaded correctly, pushing the bottom envelopes in slightly farther than the top envelopes.
* If you are printing small sizes, feed paper short edge first.
* Turn over the stack of paper in the tray. Also try rotating the paper 180°.
* Check the characteristics of the media you are using. Use only paper that meets HP specifications (see the online user guide for paper specifications). Try using different paper to see if the problem goes away. Do not use curled, deformed, damaged, or
irregular paper.
* Avoid using paper that has already been used in a printer or copier.
* Do not print on both sides of envelopes or transparencies.
* Print only on full sheets of labels and do not print on both sides of label sheets.
* Check that the power supplied to the printer is steady and meets printer specifications (see the online user guide for printer specifications).
* Clean the printer (see the online user guide procedures).
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 09, 2009 | HP LaserJet 4100 Printer
My printer shows an E that it`s out of paper when it`s not out of paper.my printer is a hp psc1315 series all in one. forestlady38
1) Check your printers ink levels.
2) Make sure there is no jammed paper in the printer.
3) Contact your printers manufacturers website. You can speak to them live if there online. Explain to them the issue.
Jul 27, 2009 | HP Office Equipment & Supplies
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Hp C5280 Paper Jam error - no paper + component fell apart
I am having a similar problem. An33651759-359a-4c42-a15c-e9b8d80fcfba.jpgyone know where this piece belongs? It came out when I cleared my millionth paper jam!
Sep 09, 2008 | HP Photosmart C5280 Printer
I have a hp deskjet d1341 printer
take off the back cover of printer and check it out for any paper left from the paper jam and then make sure you replace the back cover properly. : )
Oct 18, 2007 | HP Deskjet D1341 InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
140 people viewed this question
Seeker5211
Seeker5211
