Does it work on any other PC? If so you may need to 're-assign' the drive letter on the drive. Long solution, but doable....Does it work on any other PC? If so you may need to 're-assign' the drive letter on the drive. Long solution, but doable....
You can't post conmments that contain an email address.
try using this software to format the transcend pendrive .
use it in XP or Vista
www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
You should try and blow into the usb end of the memory stick, and also into the Port on the computer where the usb stick goes in. This most often helps. If not, you may need to write to the makers of the stick, and complain. They will most often replace it for you, if you have had it less than a year and a half.
Hope this helps,
Pennywise25
right click my computer got manage>disk management. see if it shows up at the bottom. if so make sure it has a drive letter and is formatted and is active. otherwise it might be a bad thumb drive
(WARNING: After running this low level format tool, the whole USB flash disk surface will be fully erased. Therefore, data restoration will be impossible after using this utility!
2nd
I tried this but my pendrive is not recognized when i plug it in
windows sees it and says its installed but there is nothing there and i
cant even format it killdisk will see it but says its busy and wont
display any other info on it
