My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
  • 628 Answers
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Posted on Jul 27, 2009
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
My Canon MP140 has a paper jam. How to open and remove paper?
Click here. This will take you to the Canon support page for your MP140 printer. Click on the 'Support and Service' tab.
Where it says ask a question type in 'paper jam'.
Next click on the required link, which should give you detailed instructions or a link to help you with your paper jam.
If this helps, click YES below.
Jun 30, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
My printer keeps saying I have a paper jam, but after inspection I cannot find any paper that is jammed. I also put the copy paper in the correct tray, however when I try to do any of the all-in-one...
usually you have to look at the sensors trough were the paper goes (a small pice of plastic that is suposed to move) maybe you have a blocked sensor.
Jun 14, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 AIO "Load Paper" error
Solved myself: I reseated the 4 internal wire harnesses and ribbon cables. None of these were obviously loose, but it seemed to do the trick.
Jan 06, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer no longer feeds paper correctly
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Dell 926 All-In-One InkJet Printer
Envelope stuck inside of printer Dell Photo AIO Printer 926. Can see it down inside from the loading side but no where else and it won't print anything else (won't load the paper). How do I get to the...
Raise the scanner lid as if you were going to change the ink cartridge. You should be able to see the stuck envelope -- just grasp it and pull firmly to remove it.
For suggestions on avoiding paper jams, please go to Dell's support page
Please rate this solution if you find it helpful!
~~Cheryl
Dec 22, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 all-one inkjet printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Oct 24, 2008 | Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Paper wont feed and the language is not Engliosh
the printer keeps printing green can not stop it it a
fell printer
Aug 15, 2008 | Dell Photo 964 All-In-One InkJet Printer
319 people viewed this question
k24674
jasbo
jasbo
