Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
The faucet continues to run when using the side spray.
I installed a new Marielle about a month ago. Everything was working fine. After installing new counter tops the faucet was apparently reinstalled incorrectly and after a few days of seemingly correct operation, the faucet began to pulse when operated (cavitate?) resulting in a drop in pressure to the faucet and causing the side spray to leak. There may have been a slight kink in one of the supply lines causing the problem. After disassembling/reinstalling the entire faucet assembly everything seems to work fine, except that the faucet keeps running at reduced pressure when using the side spray. Also, when I removed the diverting tee a O ring dropped of the end of the mounting body. I assumed that is was supposed to fit inside the diverter tee and replaced it. The mounting body also has an O ring which is in place. Thanks for any help or suggestions.
  • 297 Answers
Under the neck of the faucet is a small cone in the side of the body.this is your spray diverter,it may be clogged,it may be spring loaded or a presure valve you must remove and clean. then it will work right.
Posted on Jul 29, 2009
I need a replacement handle, including all the parts and hoses, on my Price Pfister Marielle kitchen faucet model # T26-4NEE
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
Jul 26, 2012 | Price Pfister Marielle Kitchen Rustic...
Looking for a price pfister marielle faucet installation instrucction. Model number026-4nzz
Call price Pfister at: 1-800-PFaucet
They have excellent customer service and can point you in the right direction.
Sep 30, 2010 | Price Pfister Marielle Kitchen Faucet with...
Low pressure to the main faucet, great pressure to the side spray
try un-screwing the screen on the end where the water comes out. Could be clogged
May 01, 2010 | Price Pfister Marielle Kitchen Faucet with...
Installed new beautiful 4 piece arch neck faucet a month ago. Have had pressure problem ever since. Hot water actually dribbles after about 3 minutes. Already tried everything suggested here. Was going to...
My husband is a plumber. He COMPLETELY agrees with u that u should get something else- of better quality. He says u get what u pay for! Price Pfister is not of the best quality! He recommends anything MOEN. They're great and rarely have problems! Good luck!
Jan 03, 2010 | Price Pfister Marielle Kitchen Faucet with...
Installed new faucet worked then all water stopped
If it has a side spray the diverter might be stuck. try flicking the spray handle on and off.
Jun 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
463 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
