WhenI tried signing in with my cellphone it said the passcode that I entered was incorrect and it was the same passcode that had been sent to my by SMS
SOURCE: 81003002
If you are sure you have the correct password, I would start with changing your user name that you are signing in with. Sometimes yahoo seems to want the "@yahoo.com" with the user name, and sometimes it does not.
If adding or removing the "@yahoo.com" part of the user name doesn't help, go through the "forgotten user name and password" steps.
SOURCE: cant delete account
If it's signed in on your phone, then type in the following address in the browser's address bar of your phone https://ssl.facebook.com/help/contact.php?show_form=delete_account, once it's opened, select "Submit" and confirm if you get any alert message. Your account will be permanently deleted.
Notice that once done is done, you will not be able to recover it, never will be.
Good luck.
Thanks for using FixYa.
SOURCE: When i try and sign in, it's saying that the user
Hi the problem is not with your password so dont change any settings ok the problem is not your end everybody else is having the same problem, sony are having some down time at the minute to update their servers and software so just bare with them for a couple of hours and it will be back on shortly.
dont try changing any settings as the problem is their end not yours
let me know if you need further assistance or if it still not working in a couple of hours.
their are loads of people asking the same question in the last hour so you are not the only one, you could try going to the sony ps3 web site and check on their for any down time,
ill check myself now and post a message when i find something out ok
plz rate this solution as i have a whole page of unrated posts, thanks
i have just got through to sony and they are doing maintenance on the network so just bare with them and it should be back on shortly ok
SOURCE: how do I sign up
Use this site to create an account:
http://www.facebook.com/r.php
Hope this will help you.
SOURCE: why does a new never
Hi.
This is actually fairly easy.
The only thing stopping you is an e-mail account, right?
Go to google.com
Then click on where it says gmail up on the top of the page.
Next, set up a new account with gmail, giving you a new e-mail address.
Then go to Facebook, and setup a new user account, if you have to, use your middle name as a way of getting a new account, and use the new gmail account as your primary email account for facebook.
This will provide you with a new facebook account.
Then after you are on facebook, go to your account, and edit anything you want to change, like your name.
Then you should be good to go.
I hope this helps you out, and good luck to you.
