Question about GE 24 in. GSD3620Z Built-in Dishwasher
Water not running
When I start the dishwasher it runs but no water is sent into the dishwasher. Therefore I have dry soap in the washer and it doesn't wash the dishes.
  • 1 more comment
  • Anonymous Nov 26, 2007
    Portable GE Dishwasher runs but won't fill with water. What's up?
  • Anonymous Nov 28, 2007
    it starts to pump water then stops. the timer goes through the whole cycle but no washing action or draining the washer is only 5 years old and i rarely use it.
  • Anonymous Dec 09, 2007
    model gsd725.....9 years old.......tried vinegar down spray arms....real hard water in my area.......this worked about 3 yrs. water just dribbles out spray arm doesn't even extend up.......don't know what is wrong.
  • 288 Answers
All these sound the same, the water inlet line is plugged with deposits from the water, especially is this is an older machine and the quality is poor. take off the front panel and remove the water supply line under the machine where it attaches to the solenoid. Be sure to turn the water off first. The solenoid inlet housing will have a screen similar to the one on the end of your faucet. If this is plugged with calcium or other deposits, it will cause these type of problems.
Posted on Dec 27, 2007
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Nov 20, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Dish soap is leaving a build up on the interior of the dishwasher
Hi. Run your hottest and longest cycle with no soap, no dishes and 2 cups of white vinegar. Also, run the hot water into the sink before starting the dishwasher. Once the sink water is as hot as it gets, then push the start on the dishwasher. J.
Jun 23, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Can't get rid of the soap...
One buy dishwasher cleaner or run bleach in it. But the reason why is because of hard water the hard water makes the soap stick to everything. And you might be using tomuch soap only use the main side not both and make sure you us jet dry. But the beat thing you can do buy water sofiner and then you can us even less soap and it will clean better and save the life of your dishwasher. Look at the film you can see, now think about the film you can't it's pritty sick
Apr 29, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Water is not spraying around and soapy water is in bottom after putting no soap for past five starts
You have an oversud problem and pump is cavitating due to too much soap. best and quickest way is to remedy is use 1 cup liquid fabric softener and let dish washer run thru complete cycle wit heat dry in off position.The fabric softener will break down the soap and remedy the problem. Hope this helps.
Feb 12, 2010 | GE Dishwashers
Can I take the bottom part of the dishwaher apart
Mkae sure you are running kitchen hot water faucet before starting dish washer. If not you are getting mostly a cold water wash thru out the cycle. Also make sure the jet dry dispenser is full. Always use the liquid jet dry as the small cubes you can get do not work nearly as well.
Jan 31, 2010 | Kenmore 15762 Dishwasher
Soap not breaking down in dishwasher
Be sure to run kitchen water hot at faucet before starting dishwasher or you will get an entirely cold water washer. Also be sure the jet dry dispenser is not empty. Only use liquid jet dry. Pay no attention if soap says with jet dry. Does not work as well. Hope this helps.
Jan 31, 2010 | Frigidaire 24 in. FDBB840DC Stainless...
I think that the problem is that these washers use too little water for rincing. Concentrated detergent residues are drying-up, solidifying on internal surfaces, including exhaust tube, and smell like...
I've got a Maytag with a similar issue.. Try this: Take a 1/2 cup of automatic dishwasher soap powder (Such as Cascade) and toss it into your washing machine without any clothes in it.
Run a whites, hot water cycle with an extra rinse to see if this will break down some of the buildup and remove the smell. You may want to run a second cycle without adding soap to clear the drain lines.
Dec 02, 2009 | LG Washing Machines
It ended up being a simple fix. Soap had dried on the floater (water sensor device) and it could not move, therefore no water was going in. I poured hot water and vinegar into the washer and ran a complete cycle and it is working fine now
Jun 10, 2009 | GE 24 in. Profile PDW7880G Built-in...
Dish washer won't wash
is the drain hose to low causing the dishwasher to fill and drain at the same time,if the water level is to low the motor wont wash the soap out of the dispenser.hope this helps
Mar 03, 2008 | Frigidaire FDBB1940D Dishwasher
Let it fill with water then add 1/4 cup of vegetable oil. Let the washer run a few minutes and open the door to see if the suds are gone. If so, drain the washer and run it through a short cycle with small amount of proper detergent to clean any oil residue from tub.
This will also work for clothes washers that oversuds.
Nov 14, 2007 | Dishwashers
GE 24 in. GSD3620Z Built-in Dishwasher Logo
642 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
