We have A 46''RCA HD. We have gone through 5 cable boxes in the past year and now the sound on the TV won't work.Is it possible that because of the cable box problems we've had that it knocked out the sound? If so is the cable company responsible for fixing or replacing my TV. IF not I would like to know of someone in the Austin,Tx area who would fix it for a reasonable rate.TV is approx. a year and 1/2 old
  • 66 Answers
Arrow HD TV Repair 2121 West Parmer Lane #106
Austin, TX 78727
Phone: 512-835-1600 512-835-7778
Fax: 512-973-3839
Bonds tv repair
1010 West Lynn
Austin, Texas 78703
(512) 476-3551
Posted on Jul 29, 2009
I just bought the tv, hooked it up to my new cable box using HDMI cable. i get some picture and sound on some channels but no HD channels at all
Try to go under the setting with the cable box and see if it has a switch to choose HD channels first. What cable companie do you have?? It could be possible that you will need to call to get HD service.
Sometimes the HD channels tend to be be late in the programming guide(I have comcast of Virginia and most channels are 700+)
send me a message in the comments and I can help further
Hope I could help!
Mar 18, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No audio on HD tv LH40 model. Tried mute and volume
yes if you use HDMI dont have sound only image, you need to ensure audio on another cable like rca audio cable. or use a SCART cable for audio\video
Feb 14, 2010 | Televison & Video
So you are telling me I need a digital converter for this TV to g
Who was not watching the months of public service announcements? You need a Digital-to-Analog (ATSC-to-NTSC) converter box to receive over-the-air (OTA) signals in most parts of the country. You do not need one for most cable and satellite box outputs--they are NTSC or HDMI. Some low-power, typically religious, stations are still analog. Note OTA may be high definition (HD) or standard resolution (SD) but will be digital.
To get HD on your HD set you must have OTA (HD TV tuner, not converter), cable (QAM TV receiver), satellite (HDMI or 5-wire RCA),or Blu-Ray with HDMI or RCA.
-Ken
Aug 18, 2009 | Hitachi 46F510 46" Projection HDTV
The picture is wider then the screen on my rear projection tv
Are you using a cable box? Do you have aspect settings on your remote? Comcast cable boxes have a hd zoom button. This will push the sides of the picture out
Apr 22, 2009 | RCA P46921 46" Rear Projection Television
Audio cuts in and out
Had the same problem with mine. Took off HDMI cable and used the HD cable (Red Blue and Green) for video and standard (red and white) cable for audio.
Problem gone
Mar 19, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Is tv an HD tv
Yes, mostly all new displays are at least 720p which display a great picture ! However, coax cable is the worst possible cable you can use. Your best bet for HD from the cable box is to use component cable. These are the 3 RCA type colored cables, red, green and blue. You will also need another two RCA cables for the audio, which is usually red/black or red/white. If you have a surround sound receiver, then you will not need the 2 for audio to the TV. These 2 would goto the receiver or you can use a better digital coax or optical cable for audio.
Also, HDMI from the cable box to display is a more expensive cable which will give you HD but doesn't always look better then component on some HD cable boxes.
Mar 11, 2009 | Philips Televison & Video
My HD only works on my video setting, but I have no sound
Ok so the sound is fine on all of the other sources,
The component is running from the cable box to the amp, and you can see it.
just take the audio Red/Whit RCA out of the cable box, and input it to Cable/TV or whatever its labled, Red White, RCA.
If you want surround, then you will have to go Coaxial((single orange RCA) or TOS out of the cable box to the Digital input on the AMP. When you use this instead of Red White RCA, your amp will automatically switch between the different types of surround depending on what the source calls for or is encoded in.
You may have to get into the amps menu and change that amps input to Digital/Coax/TOS for the surround sound.
Any more specific questions, I need the model #s.
Jan 10, 2009 | Mitsubishi WD52527 52" Projection HDTV
Problems with hearing sound from bravia LCD tv through bravia DAV-HDX275 theatre system
The fiber optic port on back on your bravia tv is only for when your using a over the air antenna and watching local atsc channels in your local market. You need to run the fiber optic from your hd cablebox if it has one or your hd sat box if it has one. If you don't have a set top box with the fiberoptic port on it you can use a digital coax cable from the cable or sat box to sound system. The only other way to get sound if you don't have a cable or sat box is to run the red and white rca audio cable from the tv to the sound system and got to the audio setup on tv and turn the tv speakers off and you might have to adjust the audio to fixed instead of variable.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 05, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Is my tv digital compatible or not
I have a Sylvania 27 inch tv from 1986. I currently have Cable TV. Is it possible that it will not work even with a converter box?
Apr 15, 2008 | RCA P46920BL 46" Rear Projection...
No full widescreen on HD broadcasts
Do you know what the aspect and resolutiuon settings of the cable box are? What brand of cable box is it?
Nov 27, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
247 people viewed this question
Top Televison & Video Experts
