Question about Audiofonics ADF-241 Car Audio Amplifier
When my car is not on the three blue lights on top of the amp are still on, but the power light on the side of the amp is not. Is it normal for the three lights on top to stay on all the time?
    Scholar:
  • 129 Answers
No it is not normal.. Normaly when lights stay on the problem is a constantly hot remote wire, but in your case you say the main power light is off.. Soo one can only assume the the problem is in the LED board it's self. This can happen when an amplifier is over heated, or has a poor soldering job. Now if you can hear white noise comming from your speakers with those lights on, then you have a simialr, but more serious issue. If it is just the lights, and not a powered up amplifier I would just let it go.. LED's draw very little power, and can't hurt anything. If the AMP is actualy staying on, I would get it repaired..
Posted on Aug 07, 2009
Internal fuse
Amps getting power that's good it seems as though either you have a cross in your bridge or you fried your amp
Apr 02, 2014 | Hifonics Car Audio & Video
On my kenwood KAC-8105D mono 1000watt amp, the blue light is out and my subs are not getting any power? What does this mean? what does the blue light mean??
Well normally a light near the controls and or where you put the wires for subs is the continuous power. There is a wire from the back of your stereo that need to be ran to the amp. It tells the amp when to turn on and off so it doesnt drain your battery.
Jun 06, 2011 | Kenwood KAC8105D Car Amp
What is small blue flashing light next to power button
Depends on the laptop model but normally but it could be one of three lights. First, the disc utility light (tells you when your hard drive is in use, either reading or writing data). This light normally looks like a square, 2 or 3 circles stacked on each other or a small cylinder. The next type of light is could be is your wifi light. This light tell you whether the computer wifi is one or off or if it is transmitting data. Normally this like looks like an antenna with semi circles coming off the top of it like radio waves. Lastly, it could be your battery light showing you whether the laptop is charging, or charged. Normally this light is shaped like a battery and may have a little lightning bolt in the middle of it. Without know exactly what the light looks like, it is hard to say but these are the three most common lights.
Good Luck and vote for me if this answer helped you out. Cheers.
May 19, 2011 | Computers & Internet
The power light comes on then it give out
jl audio 12w7 with jl audio 1000.1
get a high volt capacitor 8 or more fared a breaker fuse 100amp .Best bet is to have an another battery hook up in back of truck for this kinda set up cause this amp really pulls alot of juice
May 20, 2010 | Jl Audio 1000/1 Car Audio Amplifier
Power to the amp but the blue light doesnt turn on
probably a blown capacitor open it up and look at the capacitor see if any one of them are curvy on the top blowend
Jun 27, 2009 | Alpine MRP-M350 Car Audio Amplifier
Looking for audiofonics adf-240 owners manual.
There may be a loose wire to the lights, or the power supply or amp may have a problem. Do you have the amp mounted to your sub box directly? You shouldn't. The vibrations from the bub will kill the amp in a short amount of time. If it is noticeably weaker, you should check out all aspects of the system. For instance, if you have a dual voice coil sub, is one coil open? Is one channel on the amp bad? Is half of the power supply on the amp bad? hence half the power, and no lights?
Jun 11, 2009 | Audiofonics ADF-240 Car Audio Amplifier
Amp power protector comes on
Dis connect the sub then turn it on, don't let the wires touch or it will have a problem. If your lucky, it's just your sub that needs replaced. If not, your amp needs serviced. Rockford use to have a three year warranty... I'm not sure what they have now since mass merchants beat up the line. Hope this helps
Jun 02, 2009 | Car Audio & Video
Three blue lights blink
check you speakers and power source make sure all connection is correct
May 26, 2009 | JBL CS300.1 Subwoofer Mono Amp - 200W CS...
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
May 14, 2009 | 1994 Ford Mustang
Power lights
no that is not normal. That means your amplifier is still getting power. Try connecting your remote wire from your cd player, to an on / off switch (auto parts store) and from the on / off switch to the amplifier. When you turn your car off, turn the switch off and your amp will no longer have power.
Feb 20, 2008 | Audiofonics ADF-241 Car Audio Amplifier
Audiofonics ADF-241 Car Audio Amplifier Logo
163 people viewed this question
Top Audiofonics Car Audio & Video Experts
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
